Question about Singer 7442 Mechanical Sewing Machine
I am looking for xl 6000 bobbin shsft'do you know where this can be found? i lost my bobbin shaft and can't wind thread with out it.
  • 4,924 Answers
Http://cart.jennys-sewing-studio.com/index.php?main_page=product_info&cPath=73_101_316&products_id=1546
Here is where you can get another one for 5bucks and probably something for the shipping ...
Posted on Aug 26, 2010
How do you get the auto threading and wind in place to work on Singer XL6000 sewing machine
There are several FB and Yahoo groups dedicated to the Quantum XL-1000, XL-5000 and XL-6000 who can help you. It may be that your problem with the autothreading is the autothreader is out of adjustment, but I'm at a loss as to the bobbin winder problem.
Jul 15, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Bobbin refuses to be wound on self-winding bobbin machine. Bobbin does not turn. The thread is winding continously on the bottom of the bobbin basket. Need help.
Just off the top of my so-called head, it sounds like something in the bobbin area is not seated correctly. However, I would recommend that you do a search on FB and Yahoo interest groups (also on PSW software); it's members are MOST helpful, and will be glad to work with you to resolve this problem.
Jul 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Bobbin will not wind on self-winding bobbin machine. Need help.
I think that maybe it's not threaded properly. I have had this happen a few times and had to re thread it. I leave mine threaded all the time because it can be hard to get it done correctly.
Good Luck.
After following instructions on winding the bobbin for the fast bobbin winding system, the bobbin is not threading
If the bobbin spool is spinning, it will thread.
Take the end of the thread through one of the little holes in the side of the bobbin spool and pull out about 8" of thread. Hold onto it as the bobbin begins to spin.
After the thread has wound 5 - 6 turns, stop the machine and cut off the thread end. Continue the winding process.
Mar 14, 2010 | Brother CS-6000
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Nov 12, 2008 | Sewing Machines
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Jul 19, 2007 | Brother XL-3510 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
13 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
