Question about Viking DFBB363 Bottom Freezer Refrigerator
How do I shut off freezer - appears fan is making rattaling sound
  • Viking Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
Amana side by side fridge makes a groaning noise when freezer is shut, no ice buildup nothing, just groans when light button is pushed
When light goes out, fan starts inside. Groaning sounds like the fan is hitting on something or has a dry bearing. Spray with wd40 on the shaft
May 01, 2012 | Amana Refrigerators
The fan is loose and rattaling is the waterpump need to be replaced
if the bolts that hold the fan onto the water pump are tight & the shaft of the water pump is moving sideways when you wobble the fan then the water pump needs to be replacedhope this helps......cheers.
Sep 04, 2011 | 2004 Chevrolet TrailBlazer
I have a Danby DUF1596WE standing freezer. There is ice build up on the back wall. The fan is making a very loud noise. The freezer is still working. I had to shut it off due to the loud noise.
The chances are that the ice buildup is now in contact with the fan, hence the noise when fan hits ice.
As a short term fix, power the freezer off and let it defrost naturally, this will cure the immediate problem. In the long term, I presume that this is a self defrosting freezer, so you appear to have aproblem with the defrost cycle. You MAY find that a long power off and defrost will cause things to reset and it may well cure your problem anyway
Jul 05, 2011 | Microwave Ovens
Freezer ajar loud noise
Yes Evaporator fan that has ice accumulation in it. Turn off the unit and leave the freezer open for about an hour or two re-start it and hopefully the frost that built up from the freezer being ajar will have thawed and melted away.
good luck to you!
Jun 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
Our refrigerator just suddenly started to make this loud grinding sound..it appears to be coming from the freezer side. I turned off the ice make and reduced the freezer temperature but it still keeps...
This could be a failure of the evaporator fan. Also maybe some ice has formed from water dripping from the ice maker and had now produced an icicle which could be hitting the fan blade of the evaporator motor. Remove back cover to the freezer/fan and check the fan operation while it is running.
Mar 29, 2010 | KitchenAid Refrigerators
FREEZER IS FINE. FRIDGE STILL NOT COOLING
it sounds like your circulation fan is not working. it is located in the freezer compartment in front of the evaporator or very close to it. you should hear running either all the time except in the defrost cycle. on some models the fan will shut down when you open the freezer door and restart when you close it. if the fan is OK you have a problem in your defrost circuit. probably a bad heating element or a bad defrost cutout switch or bad connections in the freezer compartment. sometimes the defrost timer can go bad but not often. I have found in my experience that the problem is usually the other two components I mentioned or bad connections.
Mar 13, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
FRIDGE IS WARM SOUNDS LIKE ITS RUNNING CLEANED ALL DUST
CHECK THE FAN ALL THE COOLING IS DONE IN THE FREEZER SECT. THE FAN CIRCULATES THE AIR TO THE FRESH FOOD AREA. IF ITS FROSTED UP IN THE FREEZER YOU MAY HAVE DEFROST ISSUES.MAKE SURE THE DRAWER IS SHUTTING ALL THE WAY, NOTHING THAT FELL BEHIND THE DRAWER
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Maytag MFD2560HES Bottom Freezer French...
The freezer (top freezer) is making an awful noise, and there is some frost on what looks to be the fan. It sounds like the fan is whining at times. Help me.
unplug and defrost...fan is stuck with ice....make sure while in operation door shuts completely..any air will cause ice/frost build up......dont overfill freezer....thanks and have a great day
Nov 08, 2009 | Refrigerators
It is making a buzzing noise on freezer side that stops when u open the door but starts again when u close it
On some models of refrigerators, the evaporator fan (behind an access panel at the top of the freezer) shuts off when the door is opened. This fan may be making the buzzing sound.
You should be able to check by pushing in the door switch while holding the door open. The fan should come on; and, if the buzzing resumes, you know what is making the noise. The fan may be developing a problem. If it stops running, the cold air will not be distributed properly between the freezer and refrigerator.
Oct 19, 2009 | Samsung RS2630SH Side by Side Refrigerator
Viking DFBB363 Bottom Freezer Refrigerator Logo
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
