Question about Jabra JX10 Bluetooth Headset Headset
Is searching 4 passcode - Jabra JX10 Bluetooth Headset Headset
    President:
  • 1,118 Answers
It's '0000' (four zeros).
Hope it works for you.
Regards, Carlos
Posted on Oct 31, 2010
How do I remove my passcode?
(Assuming you're working from iOS 9.2 or recent versions)
From the home screen, swipe the screen down to start spotlight search.
Type "Settings" in to the search field.
Once settings opens swipe down slightly to reveal a search bar at the top of settings menu.
Type "Passcode" and select the third option down which is "turn passcode off".
Enter your passcode (re-enter if necessary).
Towards the bottom of the page select "Turn Passcode Off" and enter your passcode twice again.
Jan 05, 2016 | Apple iPhone 5c
Can I make a new password
Yes, you can
Use passcode with your iPhone iPad or iPod touch
Set your Passcode
    1)Go to settings > Touch ID & Passcode. On devices without Touch ID, go to Settings > Passcode.
    2)Tap turn passcode on
    3)Enter a 6-digit passcode
    4)Enter passcode again to confirm Change passcode or passcode settings
    To change your passcode or passcode settings, go to Settings. Touch ID and passcode. On devices without touch ID, go to settings > passcode.
Nov 19, 2015 | Cell Phones
How do reset a security passcode on an iphone 4?
You can clear it then set another one. Use recovery mode to bypass the forgotten password is proved to be a good and reliable way. Then restore your iPhone, the passcode will be cleared.
Warm tip: The best and easiest method to enter and exit recovery is to use ReiBoot. Search it on google. d307bced-4ef2-41ca-b596-1e273354a2cf.jpg
Oct 11, 2014 | Apple iPhone 4S
Can not get it paired to iphone 4
Goto Preferences (the gray gear icon - should be on your home screen
Then Bluetooth
Turn your headset on (on my phone this is done by flipping down the plastic tab that touches your upper cheek
The iphone screen should then see it and ask for a pairing
If it doesn't, one by one press any other adjacent icons until you see the request to enter the Pairing passcode
If you don't know the pairing passcode, most headsets use 0000, but if that doesn't work you will have to enter into a Google search
"(Your headset brand and model) Bluetooth Passcode"
and search the resulting links until you find it
Oct 08, 2013 | Jabra Bluetooth Headset with Adjustable...
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
I have the home security system with four cameras and DVR. It is called the 4CH Real Time DVR. The current to the unit went out and when it came back on, it is asking for a passcode to search and...
I'm not sure if this will help you, but I'd give it a shot. I would enter zeros for the password.
It is takes 4 digits, I would enter 4 zeros. It it takes 5 digits, I would enter 5 zeros, etc.
You may also try a sequence of 1234 or 12345 etc.
These will usually be a default password for many alarm systems. Meaning that if no password
was ever set up, this is what would often work.
Give it a shot,
Good Luck,
Mark
Jan 16, 2011 | Samsung Audio Players & Recorders
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
http://www.in.lge.com/Product/Manual/KU990.pdf
Jan 11, 2010 | LG KU990 Viewty
Please help
Go to the Motorola web site and find the user manual for the H500. The instructions are there. The passcode is probably 0000.
Go to the LG manual for Bluetooth to find out how to get the phone to search for the new device when adding a device. The steps are probably something like this:
1. Turn on the earpiece and the phone.
2. In the phone menu, go to Setup or Options, then Bluetooth, then Add Device.
3. Choose Search for a Device
4. The phone will find your earpiece, so select it
5. The phone will ask for the passcode, so enter it (again, probably 0000 but check the H500 manual)
6. Wait several seconds for them to synch.
7. You are ready to go
Sep 01, 2009 | Motorola Mobility H500 Headset
Passcode for Samsung WEP170
must start with headset turned off.
1) turn on headset and keep your finger pressed until the blue light stays on
2) now let your phone search for the device. when it does select it
3) the pin is 0,0,0,0
4) then it should be matched
Mar 25, 2008 | Samsung WEP170 Wireless Headset
Jabra JX10 Bluetooth Headset Headset Logo
35 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
