Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Not cleaning properly i cleaned filter used a cleaner still wont clean dishers properly
  • Fisher and P... Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
zt5534
Posted on Sep 29, 2010
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
My carpet cleaner wont stop leaking water after cleaning and i need keep vacumning up excess water
The unit works on suction and can develop a syphon if the filters get clogged. There's 2 filters that you should be cleaning after each use. One filter is located under the Flow Inidicator: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. Reinstall in reverese order. If that didn't help you may want to call Bissell Consumer Care at 1-800-237-7691 Hope that helps.
Dec 24, 2014 | Bissell ReadyClean DirtLifter Carpet...
How do I clean filter for whirlpool disher model number du890dwgq1
It will be in the bottom of the dishwasher Usually unscrews.
Oct 02, 2014 | Whirlpool Dishwashers
Bissell instruction manuals
The instructions tell you to clean filters after each use. Check the User's Guide for specifics. Quick guide though. Water tank Cap: Under the cap is filter (looks like a screen) remove, clean, replace. Locate the Flow Indicator: turn it counter-clockwise to remove the cap. Lift out the rotor and the filter underneath, Clean and reinstall in reverse order. That should fix the problem. Consumer Care phone number is listed in the User's Guide.
Aug 20, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Pool cleaner won't work
Sounds like the filter is getting very dirty and lowering the suction needed for the cleaner to run properly. If that is the case, there are two ways to address the problem. 1. Everytime the cleaner stops, clean the filter. 2. Use a manual vac and cut the pipe that comes off the top of the pump and goes to the filter. By eliminating the filter, you should be able to clean the pool a lot faster. You'll have to empty the pump basket often.
Mar 04, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My disher is not cleaning properly. It leaves
heatman101
34taqg
Nov 27, 2009 | Bosch 24 in. SHX46A05UC Built-In...
My dishwasher not cleaning properly
If your filter is dirty or "damaged beyond repair", dirt can be sent back to the dishes, glasses, flatware, etc.
Also, the water paths may have scale lining or blocking the pathways, which would reduce water pressure, prevent proper pressure, and / or block water spray.
The following link might give you some ideas... as for the filter, if you have the user's manual, the list of parts may be in the back with the index.
https://www.onegoodthingbyjillee.com/how-to-clean-your-dishwasher-in-3-easy-steps
Oct 17, 2017 | Bosch SHX46L15UC Dishwasher
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
NOT CLEANING SILVER WARE OR DISHER PROPER
clean inside with a load of vinegar
Mar 18, 2008 | Washing Machines
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
69 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
