Location am antenna on rcarcd175 - Audio Players & Recorders
Radio antenna location
the antenna is located in the roof and front fender have included a link to a schematic (basic location) , if not getting a good reception the best solution is to get an aftermarket fit antenna that mounts on the vehicle body because to try and replace this factory fitted antenna would be prohibitively costly
Antenna Amplifier in Electrical Lighting and Body Mobile Multi media...
May 22, 2014 | 2007 Hyundai Entourage Limited Minivan
RADIO ANTENNA LOCATION
Above the roof headliner.
Jul 26, 2017 | Audi A3 Cars & Trucks
Where is the power antenna motor located for a 1992 buick regal?
I have not owned a buick for years. However, the one I did have trouble with the power antenna motor was located directly under the antenna. It was in the rear fender housing. I have to remove the trunk lining on the side of the fender. It was mounted a bracket. It was easy to replace as it all comes as a complete assembly. Hope that helped
Feb 21, 2012 | 1992 Buick Regal
Where is the wireless antenna on a Latitude D610? I can't get the wireless internet option to work, and my computer suggested it could be the antenna.
Hello there,
There is actually no antenna. What you need to do is to turn on the wireless capabilities using the switch. All you have to do is to press the Fn key + the F2 key.
Good luck! Let me know if you have further questions.
Nov 04, 2010 | Dell Latitude D610 Notebook
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
My Nuvi 660 can not locate the satelites, please advise. Thanks.
There is a common problem in the antenna circuit that will cause the antenna to fail. To confirm this take a very small section of wire and carefully insert it into the center conductor of the external antenna jack, which is located on the side of the flip up antenna. By doing so you are essentially using the wire as an external antenna and the unit should get satellite lock. Do not continue to use the wire as antenna however. Garmin will charge a flat rate of $110 to repair it or you can send it to a reputable post warranty repair company like www.sharcnet-usa.com
Hope this helps you, safe travels.
Feb 25, 2010 | Garmin Nuvi 660 GPS Receiver
Where is the antenna located on a 1996 lincoln towncar
The antenna is located on the top of the rear glass. There is no external antenna mounted on the 1996 Town Car. If you look at the rear glass, the antenna is the squiggly wires at top.
Feb 15, 2010 | 1996 Lincoln Town Car
2004 power antenna
You dont actually have to take the antenna out of the car fender or where it sits, if you can remove the radio out of its deck and locate the power antenna wire just unplug it or cut it and tape it up and u should be ok. In most cases the color is blue, but if possible you want to test it to make sure. Also if u can get to the power antenna cables in the antenna location itself you can also cut or unplug the Antenna remote turn on wire, which should be blue as well. If u have any more questions just email me.
Good luck.
Jun 12, 2008 | 2004 Mitsubishi Montero
44 people viewed this question
 Grubhead
Grubhead
