Question about Acer Computers & Internet
Acer 223H clips off left side of screen. Tried autoadjust button, but just makes it worse.
Hello i would like to know how to record videos on my web cam. If anyone knows will you please tell me. thanks :)
Please follow the steps below:
  1. Go to Start, All Programs, then Windows Movie Maker.
  2. On the left side, click the link for Capture from video device.
  3. Select Next throughout the set up, making any file name changes or setting changes if desired.
  4. On the Capture Video screen, click on the Start Capture button
  5. You will see the video on the right with a time count up
  6. When you are done click the Finish button
  7. Click the play button on the video clip, or drag the clip to the Storyboard below
Thanks and regards,
Anil.B.R
Aug 17, 2010 | Acer Aspire One PC Notebook
How do you right click on acer aspire laptop
if you have the small 8.9 inch screen acer one, there is a button on either side of the touchpad...if you have the 11 inch acer one, the button isa one piece mouse button that pivots at its center point. Push on the right side to right click and push on the left side to left click.
Aug 17, 2010 | Computers & Internet
HOW DO I USE MY WEBCAM ON MY ACER ASPIRE ONE NETBOOK?
Certain models have are shipped with Acer Crystal Eye Webcam software which enables webcam at boot. I do nto know if it is installed in your netbook.
To test the webcam running Windows XP, follow the steps below:
  7. Click the play button on the video clip, or drag the clip to the Storyboard below.
If your webcam is not detected or if you are running Windows Vista click the link below.
The wesite has live chat support in case you get stuck
http://netbooks-us.custhelp.com/app/answers/detail/a_id/86/related/1/kw/webcam/r_id/166
Jan 13, 2010 | Acer Aspire One AOD150-1920 Netbook
Can someone help me connect my Acer Aspire 3680?
Your graphics card on that should push that resolution so I would probably lean toward the tv. Try changing the aspect resolution or (zoom button) on the remote to change the way the screen is delivered. As long as the resolution on the laptop is a widescreen resolution and the same for the television. Make sure in your tv settings, that the aspect is set at 16:9.
Jan 12, 2010 | Acer Aspire 3680 PC Notebook
Picture won't fit in screen
first is the picture is distorted? if no then try using the remote and push the left or right arrow keys
Mar 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shift button stiff
buy new kb for it on line alot places iwll sell it ebay will take down rd or do it yourself pop old one out top panel off 1st that goes over the screen hinges lift that up flat head then 3 screws holding kb in lift out of ribbin cable clip its in to mobo u can see it its easy thx nick
Feb 11, 2008 | Acer Aspire 3050-1733 Notebook
Can't manually adjust color
I happen to have an Acer Monitor although a later model. It has 4 buttons....one of these is the auto adjust and one other is the window that has manual controls (so to speak). If you look at it carefully...(and it should stay on the screen for at least a minute - they believe you will do something in that timeframe)...you will find a set of icons at the top. These are suppose to be visually intuitive (and they are after you have used them once or twice)....anyway, if you really want to set your colors manually and or make other adjustments....alignment et al...you use the other buttons when the manual control screen is there. Experiment a bit and you will discover what does what. FYI...all "modern" monitors have this ability....the icons differ....but autoadjust does the best job in general....personal preferences and eyesight withstanding. Good luck....a small glass of wine sometimes helps the process and reduces the frustration level the first time around.
Jan 24, 2008 | Acer AL1916W 19" LCD Monitor
Focus is way off...screen is blurry????
is the monitor a flat screen? if so, you can try the autoadjust button, which is found by pressing the monitor menu button, and cycling through.
Jan 06, 2008 | Acer X221WSD Monitor
Acer x191w monitor background is moved to the right with about 2inches of black on left side.
Here is the fix;
1. Go to Screen Resolution
2. Select Acer Monitor
2. Find Advanced Settings and click
3. Find Screen Refresh Rate and change it to 75Hz
4. After the monitor flicks, changes it BACK TO 60Hz.
This fixed the problem for me. Hope it helps. :)
Jul 18, 2007 | Acer X191WSD Monitor
Computers & Internet Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
