Question about Refrigerators
How to remove the drip tray at bottom of 2002 Frigidaire that's been contaminated by rodent droppings, in order to clean and disinfect it? Thank you.
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
How do I remove detergent tray?
Good Afternoon friend, thank you for your post!
From the information you have provided you need assistance removing the detergent tray from your Frigidaire washer, ATF8000FS. In order to remove the tray you should be able to push down on the push arrow and pull the out on the drawer. It should slide right out. If you have any troubles please feel free to reconnect. -Matt
Mar 13, 2015 | Frigidaire Affinity ATF8000FS
My Frigidaire refrigerator has a drain pan that is un remove able and has a bad smell how can I clean.
I appreciate your inquiry, friend!
If you would like to clean any dirt or debris from the drain pain you can use a vacuum attachment to get inside and clean any residue within the drain pan. You can also use warm water and bleach to help disinfect the drain pan prior to vacuuming it out. If that does not help you may want to consult with a professional technician for additional cleaning to be completed within your Frigidaire refrigerator. Best of luck! -Matt
Oct 19, 2014 | Frigidaire Refrigerators
What water disinfection?
Water disinfection is a purification process that kills or removes biological contaminations from water sources. In some cases, additional contaminations may be added to the water by the disinfection process.
Aug 23, 2012 | Brita Camping, Backpacking & Hiking
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
The unit ices up after an hour or so and then water runs down the wall and not into the drip tray
Two issues are possible.
First of all check for dirt accumulation that is blocking the water to drip but is diverting to the front panel section to flow into the wall.
Secondly the A/C must be mounted with a slight tilt thereby making the water condensation to flow/drop into the tray. If not you can remove and make a small wedge on the mounting to tilt.
Also use a good air jet or a water jet( if taken out) to clean the coils.
Jan 05, 2011 | Frigidaire FAA065M7A Air Conditioner
There is a sour smell that comes out of the bottom front of my fridge. It is a side by side Frigidaire with an ice maker. It does not smell inside, only the exhaust air and it smells up my kitchen. I have...
There is drip tray underneath the unit. Depending on model, there are multiple ways to access. This tray needs cleaning regularly. Once clean, sprinkle in Baking Soda to keep odors down. Cleeaning this on a regular basis is the only way to beat this smell.
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Remove drip tray from bosch KTR1670GB
YOU MIGHT TRY TO UNCLIP THE COMPRESSOR AND MOVE IT OUT SLOWLY AS HOT TO KINK THE COPPER TUBING,ALSO MAKE SURE YOU USE CLAUK UNDER THE DRAIN PAN SO IT DOES NOT LEAK,HOPE THIS HELP,THANKS-MIKE
May 30, 2008 | Refrigerators
Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Mar 10, 2008 | Refrigerators
Refrigerators Logo
252 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
