Question about Sport & Outdoor - Others
I have a t102 program keeps saying lube belt. can not get tradmill to work. thans
  • 857 Answers
Temporarily suspend the message for five miles by holding the STOP key for five seconds.
You need the lubricate your treadmill
Follow the steps mentioned below:
Procedure to LUBRICATE the running belt
1) turn treadmill off, and unplug from the wall.
2) Using the T-Wrench or Allen Wrench loosen the rear roller bolts 10-12 counter-clockwise turns.
This should give you enough slack in the running belt to get your hands underneath it.
3) Lift up the running belt as far as you can, then squirt the silicone oil in a zig-zag pattern
across the entire running deck surface. It is best to use the entire bottle (40-50ml) of silicone
that is supplied by Horizon Fitness. [Do not apply silicone oil to the Running Belt]
4) Lay the running belt down, and then tighten the rear roller bolts clockwise the same number of
turns you had done in step 2.
5) Plug unit into wall, flip power switch on then press start. Let the unit run for 3 minutes. Then
walk on the unit for another 3 minutes, This will help spread the silicone oil across the running
deck.
6) Wipe off any excess silicone oil that may have seeped out from underneath the running belt
with a damp cloth.
Waxing the Running Deck
Procedure:
1) Turn treadmill on and let it run at the highest speed for approximately 2 minutes.
2) Turn machine off.
3) Loosen belt by turning left and right roller bolts counter clockwise for 10 complete turns using your T-Wrench/Alan wrench.
Note the positions of each bolt on both sides, as you will want to return them to the same position.
4) Lift the running belt to expose deck. Apply paraffin wax to deck from front to rear, making sure to cover entire surface of deck
usually covered by the belt.
5) Tighten the belt on both sides by turning the bolts clockwise and positioning them as they were before you loosened them.
6) Turn your treadmill on and let it run at the highest speed for approximately 2 minutes to evenly distribute the wax.
Posted on Aug 26, 2010
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
How do you lube the deck belt
use a good silicon spray. it goes under the belt between the belt and walking deck. apply in a "s " pattern to cover entire area of walking belt.this keeps the friction down and squeaking noises
Apr 16, 2014 | Reebok Exercise & Fitness
Says to lube belt .did that but when the safety key is inserted still saying lube belt
You must LUBE the deck belt, every week, otherwise you will have a WORN deck belt and replace with the rollers bearing. Now LUBE with 100% silicones lube.
2) lube THE Rolleler bearings too.
RUN the software calibration for easy diagnose, and troubleshooting
God bless you
Nov 17, 2012 | Exercise & Fitness
My freespirit tradmill error 5606
1) LUBE the deck belt, this happen because the lack of maintenance , produce shut down for to protect electronic system,to due the enough friction between deck vs deck belt., maybe deck worn.
2) lube the rollers bearings
3) test the motor input voltage, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
After fix it RUN the software calibration for diagnose, troubleshooting.
God bless you
Jul 13, 2012 | Exercise & Fitness
My landice 8 tradmill says safe and will not move
1) rUN THE SOFTWARE CALIBRATION for diagnose and troubleshootin.
2) Lube the deck belt
3) Lube the rollers bearing
4) Measure the input voltage motor, if there are the motor need repair
5) Measure the output voltage boad, for input voltage motor, if there are not the board is faulty. see the block diagram
God bless you.
Jun 18, 2012 | Landice Exercise & Fitness
Pro form 400gi belt adjustment
should be a allen wrench adj on the rear of the tradmill
Nov 11, 2011 | Exercise & Fitness
It is saying schedule maintance see owners manual
The manual should point out specifics but this is usually a message that is generated by the miles on the mill. Most important maintenance on a treadmill is keeping belt lubed. We also vac under the hood( motor area) to get out dust, lent and debris. and lube elevation mech. Check owners manual for type of belt lubricant.
Nov 16, 2009 | Startrac Fitness Products Lamar L1400...
Treadmill tx400 wont work for llonger then 6 seconds
Sportcraft tradmill are very safe. First check and make sure there are no recalls on you unit. Do that on line or call Walmart where you most lickly got you treadmill. Try lubing you deck wich is under the belt. This is something that needs to be done to stop friction... Frition may have worn down the motor. Get back to me
Oct 10, 2009 | Exercise & Fitness
9 inch screen---model " RD0946 T102
hold the channel up and the volume up button together for 2 seconds and it will go off.
Sep 26, 2007 | Philips Magnavox 27MS343S 27" TV
Sport & Outdoor - Others Logo
50 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
