Question about Janome Memory Craft 9000 Computerized Sewing Machine
I can't seem to get the tension right on a straight stitch, or any stitch for that matter.............now I remember why I don't sew anymore:( Haven't been able to solve this issue since I bought it used.....any ideas? susie sewnsew
  • sdewren Aug 25, 2010
    This link offers no help, and no posts regarding tension issues. I have used the manual prior to this inquiry anyway, with no satisfaction.
  • 4,924 Answers
The tension on the thread is made like follows..
for the upper thread..is made from the button with numeric values from which the thread is going when you thread the machine ..and for the bobbin tension ..is made from the bobbin case ...which has a side screw on it ...the tidier that screw it is ..the tension will increase exponential ...thats all...
To have a balanced stitch ..all you have is to make those 2 threads to have equal tension ..and this can be felt by hand...just pul them by the thread ..and see if they feel the same ...if one is more tensioned than the other ..either tide the one that has less or loose the one that has more
Posted on Aug 26, 2010
  • 10,865 Answers
Hi Susie. Do not be discouraged. Go to this link http://www.janome.com/index.cfm/FAQ
and learn about the tension adjustments. J.
Posted on Aug 25, 2010
Haven't used my Kenmore sewing machine #385.19153 for a long time. The display shows "bobbin winding" I don't remember how to change for simple straight line stich
Try pushing the bobbin winder spindle to the left. It's on the top of the machine to the right of the spool. When this spindle is pushed to the right, the sewing machine is ready to wind a bobbin. Once the spindle is to the left, you should be able to select a straight stitch (stitches 10-12), set the stitch length and check the thread tension.
See https://www.manualslib.com/manual/505279/Kenmore-385-19153.html?page=44#manual for a picture.
I hope this helps.
Jul 04, 2017 | Kenmore Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
How do I get my sewing machine to sew with correct tension and straight stitches?
Over time, internal adjustments and servicing is required, at a sewing centers, service dept.
Take it in, have them look and repair, pay the nominal charge!
you will be glad you did!
Apr 16, 2015 | Sewing Machines
Thread tension
Needle/fabric/thread combination is wrong. hope this helps
Aug 17, 2017 | Sewing Machines
The bottom stitching looks like a line and not stitches the top stitching is fine
whether its bias or straight does not matter to machine. loosen the bobbin tension and put more tension on take up spring by inserting a screwdriver in the slot of the top thread tensioner. turn to right.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
Tension problems
Hi, check that the thread tension knob makes only one rotation from 0 to 9 and stops at each ends, see that it moves in and out as you increase or decrease the tention, see that the small tension wire to the left of the knob is still in place, in any of these fail you need to replace/repair that assembly.
Aug 11, 2009 | Singer 7462 Mechanical Sewing Machine
I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
Mar 28, 2009 | Brother XL-5500 Mechanical Sewing Machine
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Janome Memory Craft 9000 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
