Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
Melted rubber gasket, black rubber residue inside dishwasher I had a problem with the latch not connecting and therefore could not turn on the dishwasher. After, two months with Sears repairmen, dishwasher still did not work. I noticed as I put my head into the dishwasher to check on a buildup of residue this black glue all over the inside. Repair man stated it was animal fat. After spending some time looking at the situation under the door and inside I determined it was the gasket. He order me a new one but I can't get the rubber glue out of the tube inside.
  • 530 Answers
That is because Sears highers nimrods. sorry for the honest answer but it is the truth. Just a tip any time you get a Sears tech in your home and the first thing they do is get on the phone with tech support it's a bad sign that they DO NOT KNOW WHAT THEY ARE DOING.
I notice when there is that black substence inside it is because between the inside of the door they stick this rubber sticky thiing it'ss called a sound absorber and after time they dry up and fall between the door right into the dishwasher. this might be what is happening to you. The only thing that might help you is a heavy duty degresser and/or try 409 it works wonders. also you might want to take the door apart and check inside to see if it is crumbling. if it is remove it. it serves no functional purpose
Just curious did this happen after he repaired you door switch?
if yes this is more than likly what is happening
good luck i hope this helps
Posted on Aug 25, 2010
How do I replace a dishwasher sump pump gasket?
Would love to help but need manufacture and model #
Jan 28, 2015 | Dishwashers
I have a Bosch SMU2042UC/14 dishwasher. The door will not latch. I have replaced the door latch and handle and still have the same problem. The dishwasher still works, will a little leaking, even though...
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Sep 12, 2008 | Bosch Dishwashers
Tip
Gel Dishwasher Detergent
Allbrands does not recommend gel detergents
Gels typically contain bleach - primarily chlorine bleach - which causes rubber seals to break down and leak.
  1. Gels often leave a whitish or cloudy film on glassware.
  2. Gels tend to stick to the inside surface of the dishwasher, never really being rinsed off.
  3. Gels are intentionally thick so that they stick inside the soap cup and don't run immediately into the bottom of the dishwasher. Therefore, they leave a sticky residue inside the soap dispenser, actually cause it to clog and not open during the timed sequence.
  4. Gels are not effective in hard water - and almost always leave spots.
on Jun 15, 2011 | Dishwashers
We are having water leak from the bottom of our Roper Dishwasher door. THe model # is RUD5750DG3. I have taken the inside door frame off and found a small white rubber seal had dislodged inside. i...
Step 1:
Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
Step 2:
Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
Step 3:
Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
Step 4:
221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine Step 1:
Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
Step 2:
Open the door completely and remove the bottom dish rack.
Step 3:
Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
Step 4:
Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
Step 5:
Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
Step 6:
Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door Step 1:
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step 2:
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step 3:
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step 4:
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step 5:
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Apr 06, 2008 | Dishwashers
Gasket melting
Awesome...
Try AMAZON FOR THESE parts...
((amazon be cool... dogs drool & cats rule)).
4X Sealing Gasket Rubber Ring Replacement Seals For Ninja Juicer Blender...
Jan 28, 2014 | NINJA Blenders
Water leaks from door during last cycle
Sometimes residue builds up between the gasket ( rubber on the back of the door ) and the unit itself. With the door open clean the inside of the washer where the door touches it when closed, clean the gasket too.
When dishwashers aren't run frequently the gaskets can dryout and shrink, this creates a gap in the gasket and allows it to leak. New gaskets are available from your dishwasher manufacturer.
Dec 30, 2010 | Estate 24 in. TUD6700KQ / TUD6700KT /...
Black speckles are all over the dishes. It looks
Remove all inside racks.filters and check for "something"
It is possible for some rubber components to turn to carbon black. Scrape around inside of hoses to check for this , if found, replace.
Sep 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Black soot on plastic in dishwasher
You can get a product called dishwasher majic. It is used to clean the tub of a dishwasher. Big box stores (LOWES, HOME DEPOT) should have it. There is not charcoal in the unit. I suspect is grease from the rubber seal around sump assembly.
Jul 23, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Black residue
Maybe a ruber washer is breaking apart, But my advise is take the inside apart clean and inspect it and then test it.
Dec 17, 2007 | Amana 24 in. ADB2200AW Built-In Dishwasher
Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Step
Step
Step
Step
5
Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
451 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
