Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My dryer turns around but there's no heat? What's up?
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Crosley CDE4700LW0 FRONT LOAD DRYER
Shut power off to dryer at breaker. Pull the two wires to thermostat off terminals. Using electrical tape wrap around wires to join them. This will bypass your thermostat. Turn power back on. Start dryer. If it heats your thermostat is faulty. If it doesn't heat it is most likely your heating element.
Dec 10, 2012 | Crosley Dryers
The heat is not turning on and it quits after around 10 to 15 mins
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | Frigidaire Electric Dryer
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Gas dryer is not heating
in the back there is a cover [first unplug the dryer] then take the cover off that will give you access to your heating coil.
Dec 20, 2009 | Kenmore Dryers
Dryer does not heat up what should be done to fix it
There are 2 main causes for the dryer to not heat up. I assume it comes on and "runs", that is, the drum turns.. but no heat. If this is the case... check the fuses in the breaker box of the house. If it is a 220v. dryer it will need 2 fuses. Turn off main power to box before messing with any fuses. If you switch the 2 fuses around, see what the dryer does. If it fails to come on, then the fuse needs replaced and all should work. If there is no change, then the heating element might need replaced.
Oct 13, 2009 | Dryers
Dryer heat but what turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Mar 28, 2009 | AEG T57800 Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Dryer heats up, drum won't turn. any suggestions?
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Bosch Axxis WTA 4107 Electric Dryer
DRYER HEATS ,BUT DOESN'T TURN
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Nov 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
