Question about Dewalt DW744S 10" Portable Table Saw with Stand
How to change mitre saw blades - Dewalt DW744S 10" Portable Table Saw with Stand
  • 2,176 Answers
You need to remove the "throat" plate and raise the blade fully. UNPLUG SAW FIRST there are 2 wrenches on the side one for the hex nut and the other for the arbor, the threads are standard. let me know if you need more assistance
Posted on Aug 26, 2010
HOW DO I CHANGE THE BLADE ON A 36-070C MITRE SAW
Not sure about the Delta. I've had both a Craftsman and a Dewalt. On both of those, the pivoting plastic guard pivots on a plate on the side of the metal guard. The plate isnt easy to see. You rotate the plastic guard all the way open and you see the edge of the plate held in place by a screw. Remove the screw and the plastic guard and the hub along with the plate it's mounted on can lift up an half inch or so--far enough to get the blade screw off the arbor.
There's a push button somewhere that locks the blade from turning so you can turn the screw in the center of the arbor with a wrench.
Sep 16, 2014 | Saws
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
Changing the blade on a power mitre saw
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Oct 23, 2009 | Saws
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I purchased the Bosch saw blade on Ebay
If the arbors the same and you're running with in the RPM rating, it will be fine. But ALWAYS wear your safety glasses.
Mar 15, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Dewalt DW744S 10" Portable Table Saw with Stand Logo
136 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
