Heat exchanger overheating boiler locking out no ch or dhw?
  • 43,501 Answers
There is probably a sensor that in bad or the brain went wacky...but to really help you I need to have a make and model of your boiler...from the code it sounds like a Weil McClain Ultra but others could have the same coding...
Did you try to reset it??? Is a pump bad???
This may take a hands on look to find the exact cause...
heatman101
Posted on Aug 25, 2010
  • killayjack Aug 27, 2010
    Worcester Geenstar 28i junior condensing combi boiler, it will fire up,after 10-15 seconds shutdown heat exchanger too hot to touch. No ch or DHW?
Hi my baxi 105he dhw has stopped heating the water flow rate is ok,when i try ch the temp led,s rapidly rise up to 80 degrees then the boiler shuts down
Indicates low water flow. possibly bad electrical connection to flow detector in dhw pipe or seized dector in pipe or blocked up heat exchanger. certainly a blockage somewhere in the pipes
Oct 11, 2017 | Water Water Heaters
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
Dec 20, 2012 | Water Heaters
Valliant vuw 282 boiler
check gas pressure and when water gets cold see if voltage to gas valve loose pressure switch wiring could also do it or unit overheating and shutting off
Dec 17, 2017 | Water Heaters
Ideal boiler no heat to radiators but hot water still working
check the divertor head and valve.
sounds like it ist adjusing from dhw to ch.
take head off(remove pi at back,or side pin) and push pin in valve when calling for ch,if it works then the head has gone.
Nov 19, 2009 | Honeywell Programmable Thermostat Heater
Combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Dec 14, 2008 | Water Heaters
Ariston micro genus combi boiler central heating works okay but domestic hotwater fails to rise but burners seem to be lit and the boiler doesnt appear to cycle dhw temp gets to about 30 degrees instead of...
having found a circuit diagram, realised that the divertor valve was electrically operated.i unplugged this then unclipped the motor from the valve body,the diverter valve is spring loaded and once i'd removed the motor the spring raised the valve to divert water through the dhw heat exchanger,giving us hot water but no heating, if i refit the motor the problem comes back heating no dhw.ordered new motorised valve assembly £30 next day order .
this was a simple fix without having to drain the system down.
Dec 07, 2008 | Heating & Cooling
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
