Question about KitchenAid KTRA22ELSS Top Freezer Refrigerator
I have a standard Freezer-top, Frig-bottom single door Kitchenaid (Model # KTRA22ELSS01) that has been dripping water from the water dispenser for a few months now. It is slow, but enough to fill a door tray in a day or so. Ice maker seems fine, no sign of leakage. With cover off, when I run water, air bubbles flow back up into tubing, drops of water slowly form on spout and drip. What part (and part #) do I need to order?
catriver
  • 878 Answers
SOURCE: Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Posted on Apr 22, 2007
  • 1122 Answers
SOURCE: drip/moisture tray inside base of kitchenaid superba refridgerator
need mor info,is there water in the bottom of your frig. or freezer,let me know more-mike
Posted on Oct 12, 2008
  • 306 Answers
SOURCE: ice build up under rolling tray in freezer
Yes you are right there is a drain tube in the middle of the coils. You need to remove the back panel and you will see the coils of the evaporator (freezer) and right underneath you will see drain tube. Now more then likely it is plugged with ice so take some regular table salt and two or three teaspoons on the top of the tube opening will break it loose and start draining. Take some regular tap water and pour down just to flush the tube and inspect the bottom collection pan under the fridge and see how much water is coming out. Be sure to have unit turned off when you do this cause the fan will run inside the freezer compartment other wise. Hope this helps you. ken
Posted on Jan 11, 2009
  • 1214 Answers
SOURCE: Kitchen Aid Super Ba refrig..water dripping from water spout !
To stop the dripping now, turn the water off.
The problem is there is either mineral caught in the seat of the dispenser valve, or the dispenser valve seat has a bad place in it. Removal and cleaning/replacement is required.
Posted on Jan 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 02, 2009
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
The freezer door leaks water from the water/ice dispenser. The dispenser fills up with water. Items in the freezer door almost seem as if they never freeze. All items in the door are much less frozen...
Leaky dispenser-------
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Sep 09, 2011 | KitchenAid KSCS25FKSS Side by Side...
I have a GE PTC22MFMBLCC Top Freezer Refrigerator. I recently noted that the water line that dispenses the water to the ice tray has a drip leak. The drip starts at the back end of the tube. Now my...
the water valve is bad it is in the back under the frig. go to appliacepartszone.com put in the model # it is easy to repace just unplus the frig first
May 26, 2011 | GE PTC22MFM Top Freezer Refrigerator
Replace door on Kitchenaid bottom freezer 2 top door model
Switch from white to red wines and drink at room temperature, or buy a new single door cooler that suits your fancy. The bolts may line up because of a single door model that shares the same chassis, but the cost and trouble of getting a matching door may not be worth the trouble.
Feb 14, 2010 | KitchenAid KFCS22EVMS Stainless Steel ...
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
IWater does not dispense.
Good day,
The hum is normal. That's the water valve in the rear of the machine being activated.
Lots of plumbing to be checked.
Water line starts at the dispensing outlet in the door, and runs thru the door to the bottom of the hinged side.
From there it goes to the filter,
'From there it travels under the machine into the cooling reservoir mounted back of the fresh food section behind the crispers.
From there it travels back out and runs to the water solenoid mounted on the back rear of the machine.
One of these lines or their fittings has failed.
It's a look-see repair.
Also, there is a remote chance the water line running inside the freezer door froze, causing this problem, and would require the machine be shut down (unplugged) and the door be allowed to defrost completely.
Nov 16, 2009 | KitchenAid Refrigerators
Water dispenser doesn't work
I have the same problem with a 2002 model. Icemaker working but no ice or water comes out the door dispenser. Also the light in the door is not working (i.e. no electricity getting to the door.)
Just had a service call. They told me that the whole door needs to be replaced because the wires that power the door are broken from normal opening and closing of the door. $1500 repair!!!!!!!
(KitchenAid did a POOR design with this frig. Open your freezer door and look toward the floor. On the left side, you will see a rope-like thing coming from the freezer to the door. Everytime this door gets open and closed, it crimps the wires... and thus, eventually they break.) The newer models have concealed wiring.
Two of my neighbors had the same problem with this frig a few years ago and KitchenAid replaced the door at no charge. I just spoke with KitchenAid. At first they told me that I was out of warranty. When I told them this is an obvious design flaw, they told me they would give me the new door since I have 3 other registered KitchenAid products. I have to pay for the repair service, which will be about $200 plus the $75 service call I had today. Better than buying a new frig.. but still frustrating because of the design flaw.
Aug 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Jul 09, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
KitchenAid KTRA22ELSS Top Freezer Refrigerator Logo
44 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
