Question about Watches
I need a new casing for the above watch. . . it is the silver one and has a plastic body to the case.. . i need the plastic body
  • 831 Answers
I have no ideal what watch you are talking about. If its on an ad on here, those change all the times. You will have to be more specific thank you,
Posted on Aug 25, 2010
Changed battery on Accurist BJ3547 as hands stopped though digital signal was still OK. New battery installed, digital signal still OK but hands still don't move . A video said a reset req'd, How?
  1. The "AC "or "All Clear Circuit" button if the watch has one will be found on the back of the movement. It will usually be a small silver or gold dot marked "AC" or reset. In some cases it will be a small hole or plunger you depress with a pin punch.
  2. Clear watch memory. Look for and find the small gold or silver dot on the back of the Seiko watches movement. It will be marked "AC" if it exists. Use the metal tweezers and touch the "AC" button with one prong and the battery with the other. In some cases you just push in the plunger on the "AC" button. In the case of a plunger or hole press it with a pin punch.
Aug 14, 2016 | Accurist Watches
I got the plastic cover off the face but cannot figure how to get to where i would put a battery in
Most pocket watches open in the back. Usually you have to have a very thin bladed instrument to pop off the back of the case. Since this is a gold watch I would take it to a jeweler to look at it since it is very easy to scratch up the case if you aren't careful.
Jan 28, 2014 | Jules Jurgensen 7381 Pocket Watch
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
Polyurethane Digital Round Case Watch - Black/Silver
Polyurethane Digital Round Case Watch - Problem with the Watches Polyurethane Digital Round Case Watch - Black/Silver
Oct 12, 2011 | Watches
What kind of battery does the texas instruments model 101 watch use?
I am pretty certain that this watch uses two #386 silver oxide button cells. Alkaline cells would work, too, but they'd burn out more quickly--not that batteries last all that long in this watch, anyway. I'm basing this on the slightly newer (~1976-78) plastic-bodied TI LED watch that I have in front of me that I believe contains the same time keeping module as the original model 101.
It is also possible that the earlier watch would have taken #357 batteries, which are the same diameter as #386 cells but slightly taller. Both battery types were popular in LED watches of the time. However, I would suggest starting with #386 cells, as I destroyed the case back of a plastic TI LED watch many years ago by trying to use #357 batteries instead of the slightly smaller 386s. Both batteries put out the same voltage, so the watch will light up with either. However, the case back won't close if the battery is too tall--and if you force it, you can bend, distort, or shatter (in my case) the all-but-unobtainable case back.
Have fun with this watch! Mine still lights up and keeps good time.
May 28, 2011 | Watches
Armitron Men's 204379BKSV Silver-Tone Stainless-Steel Bracelet and Black Dial Dress Watch, we replaced the battery and can't get the back on the watch.
Usually you would need a watchmakers press for closing the watch back. Without proper tools it is quite difficult, but you can try the following. Take a leather belt and lay it flush on an even, solid surface (stable table will do). Undo the strap (both ends) from watch case by pushing spring bars inwards with pen knife. Lay the watch crystal face down on the leather belt. Belt must be wider than watch itself and the leather must be quite hard and even, not soft. Find the small groove on watch case back and align it very carefully to the watch's winding stem, so, the stem goes directly in the middle in protrusion. Slightly push the case back into the watch case at that groove point and gradually apply pressure with fingers going all way around the case back. Use your body weight if needed. You should hear "click" sound when the case back jumps in to place. If this does not work, there is no other way, but to go and see watchmaker. Hope it will work for you.
Feb 27, 2011 | Watches
How is the case dimention of a wrist watch measured......what is all is included?
If you are looking to purchase a new watch, you have likely seen that there is a measurement for the watch case. This does not mean the box which contains the watch. The watch case is the space between the two arms that extend above and below the watch where the band attaches. The end of the band will fit in between the watch case. You will need to know this measurement both in purchasing a new watch and in looking for a replacement band. Often, watch makers give this number in millimeters, and for that reason, you will need to use a metric ruler to make the measurement.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. Find the watch case. It is the space where the end of the band attaches to the watch face. Refer to the image for a picture of the location of the watch case.
  2. Using the metric ruler, measure the distance from the inside of one of the arms to the inside of the other arm. Watch makers use the inside measurement when creating their watches, not the distance from the outer edges of the arms.
  3. Write down the measurement on the piece of paper. Measure the other watch case, but they should both be the same measurement.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 28, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
I need user manual/instructions for Slazenger, model not known
mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
Jun 27, 2010 | Watches
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
Watches Logo
16 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
