Question about Whirlpool Duet GHW9150P Front Load Washer
I just started the washer and it is beeping and saying LF
    Brigadier General:
  • 8,619 Answers
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: WASHER STOPS AND SAYS LF
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Why is my washer stopping and saying LF before it even starts?
LF means long fill. Could be caused by low water pressure or a restricted water input. Make sure that hoses are not kinked or crushed. There is usually a fine mesh screen in the water inlet at the back of the machine. Turn off the water supply valves, remove the hoses from the machine and check to be sure that the screens are not clogged with dirt.
It is also possible that the fill valves are not opening as they should.
Here are some help videos.
washing machine slow fill YouTube
Oct 08, 2014 | Kenmore Washing Machines
We just bought the washer and now it will stay on for 5 mins then all buttons blink and it says LF
LF stands for long fill,if it takes longer than a preset time by the machine it will go to LF,check water fill hoses for kinks,plugging that will slow down water fill time
Sep 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Theres a code "LF" beeping....
Hello there and thank you for choosing fixya
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
  • Slow Fill- low water pressure reduces the speed at which water flows into the machine.
    • Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
  • Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
    • Contact the water company to verify the pressure being supplied to the house
  • Error Codes- LF for long fill or FH for no water detected.
    • A plumber may need to be consulted if the pressure is found to be too low.
May 16, 2011 | Washing Machines
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Letter LF appear where the time should read. The washer just beeps and does not finish the load
This is a long fill (LF) check the inlet hoses for the screens being clogged...if it takes longer than 10 minutes to fill ..it cuts off and shows LF ..check that either water valve is not turned off or almost turned off...also, alot of people just use cold...make sure the selector is set for cold/cold if using this cycle...another possible fault is the mixing valve is bad/or going bad..Either way consentrate on this and you'll find your solution
Bruce Denton
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Apr 30, 2009 | Washing Machines
Washer will start cycle then stop and LF starts blinking on the screen
From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
93 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
