Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
We have a new side by side Samsung refridgerator and it has a bad odor. we have cleaned the whole thing out twice, moved ALL the food out and placed it in another fridge. the smell is still there.
I'm having the same problem, and have isolated the source of smell to be inside the deli drawer box... but I cannot figure out how to get the cover off the box. It comes out of fridge, disconnect the wire at back... but cannot open the "container" that the draw fits in.
Posted on Jan 08, 2011
Very bad smell coming from my Samsung refrigerator
most refrigerators have a small drainage hole leading from the inside rear of the compartment to an overflow container behind the unit, pull the unit away from the wall and check if the liquid in the container has become stagnant, if so simply clean it out and run a small amount of bleach down the hole to disinfect the tube.
hope this helps.
Nov 11, 2013 | Samsung RS261MDWP - 26 cu. ft. Side by...
Food rotted in our refridgerator and the smell is in the seal can the seal be replaced or taken off to clean
should come off if it is not glued. it is secured in a groove or has little knobs that stick in holes, you can tell if you just pull it away a little. wash it with bleach/water really good, along with the fridge interior. the odor will go away!
Oct 15, 2012 | Dometic NDR 1292 Refrigerator
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
I purchased a Kitchenaid Refridgerator 6 months ago. I changed the filter at the bottom about 3 weeks ago. Ever since then, my refridgerator has a bad odor. I have completely cleaned the refridgerator and...
If you purchased this machine NEW 6 months ago, everything on it is under warranty. You should contact the selling dealer to verify you are entitled to a free service call. Changing the filter is routine maintenance and in no way should affect the warranty.
Oct 25, 2009 | KitchenAid (KSRD22FKST) Side by Side...
My refridgerator is not keeping cold any more? what is the problem? The model is Ge GSS22WG. it does not freeze or keep things cold, all of my food went bad. I need help I dont have the money to buy a new...
it could be an air flow problem. Pull the unit out, unplug it. Clean out any dust, dirt, or anything else you see in there. Also when you push it back in make sure you have a few inches clearance behind and to each side of unit . Good Luck.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
Odor that smells like gas going from the refrigerator
Mold and mildew can cause problems like this. It is even possible that a small animal may have invaded your home and gotten into the box somehow. Cleaning the inside of the box with a dilute bleach solution may help. For continuing odor absorption, place an open container, say a 1/4 cup, of baking soda (bicarbonate of soda) in the compartment. Change as often as once a week. The powder will absorb the odor.
Jan 15, 2008 | Whirlpool ET1FHTXM Top Freezer...
Bad odor in freezer
the only source for odor in a refrig is from food. check to be sure that nothing has gone bad in the refrig section as well as air circulates back from the fresh food section as well as the freezer. if you stil cant find odor source try charcoal or unscented kitty litter in a small container to help remove bad odors..
Dec 12, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
162 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
