Question about Hotpoint HSS25GDMWW Side by Side Refrigerator
I have a hss25ifmdww Serial No GD283170 the fan in the freezer keeps running and has only shut off once today we moved it out and cleaned all the dust and lent that we could get out can you tell me what the problem is Thanks
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: refrigeraotr is out but freezer still works
doesnt make adiff how you loaded freezer, shouldnt affect fan operation anyway. if you have a meter you can check for proper voltage(110v) to fan wires and if you have power youll need to replace fan, easy enough to do just a few screws and about $50.. part number 5304445861.
Posted on Oct 21, 2008
Todd_pdx
  • 22 Answers
SOURCE: Freezer coils regularly freeze over
You have an automatic defrost problem. Here are the three components that can cause this defect in order of most common to least. #1 defrost timer or equivalent adaptive defrost control board, #2 defrost termination thermostat (should be replaced regardless since it has been frozen in ice several times) #3 defrost heating element(rarely fails but is possible). If you have a meter you can check the thermostat and element for continuity they should show an infinite reading if they are operational. the termination thermostat must be below 35 deg f to show a closed circuit.
Posted on Apr 02, 2009
  • 7 Answers
SOURCE: Freezer AND Fridge just QUIT!! Lights on, fan
If it is an auto defrost model check the defrost timer has not stuck.
Posted on Jul 22, 2009
  • 146 Answers
SOURCE: freezer fan runs for hours
When compressor cycles off, your freezer fan should shut off as well !
Freezer fan should not be spinning while compressor off.
You might need a control board replacement, that controls fan.
If you are talking about compressor run time, that is a bit excessive, usual causes are dirty condensers but you say they are clean - are your condensers at the bottom of the unit ? If so make sure the condenser fan next to the compressor is running too, blowing air ont he condenser.
Posted on Sep 26, 2009
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
It keeps going through a start up process (clicking and the fan come on then off quickly) at first staying steady then getting longer in the start up process.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
Oct 28, 2015 | Frigidaire Refrigerators
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
Model HSS25IFMDWW The freezer has stopped cooling and I asume the fridge will shortly as well? What is the typical problem to look for?
Can you hear the compressor running? Pull the unit out from the wall and see if you can hear it and also look at the evaporator fan to see if it is running. Post back your findings.
Jul 21, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I woke up one morning and the fridge is not working but the freezer is working great. The fridge does not want to get any cooler than it used to be, it is not keeping our products cold. My fridge freezer...
the damper vent door between the freezer and fridge has stuck shut due to being frozen,you need to remove the freezer wall on the inside rear area to see if this door is shut and try to get it to move,also make sure the evaporator fan is running too so air gets moved from the freezer to the frideg
May 19, 2011 | Hotpoint RFA51 Bottom Freezer Refrigerator
Freezer fan runs for hours
Sep 26, 2009 | GE Refrigerators
Freezer works fridge doesn't both worked yesterday today fridge wont
Hi, Check and see if the condenser fan motor down by the compressor is running. Sometimes when they get moved, something will get into the blade and stop fan.
That will overheat the compressor and cause it to shut off on safety. If that fan is running, check the fan inside freezer and look to see if frost is building up on inside rear freezer wall.
Please let me know if this helps you or if I can assist you further.
Vic
May 30, 2009 | Refrigerators
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Hotpoint HSS25GDMWW Side by Side Refrigerator Logo
26 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
