Question about Centrios (121-9015) FM Radio
Setting clock on model 1219833 - Centrios (121-9015) FM Radio
How do I preset channels on the Nexxtech AM radio Model 1219833?
The most common way to set those buttons is to tune in a station and then press and hold the button down that you want to set it to. It will beep of flash to show you that it has preset.
Jun 18, 2014 | NexxTech Travel Alarm Clock (63-8042)
How do I set the clock
Generally you press clock, type in the time and then press clock again. Galanz have a website where you can download user manual.
Mar 27, 2013 | Microwave Ovens
How to set time on model 13003
Hello
Get into this link. You can get all the details for your clock radio from there.
lib.store.yahoo.net/lib/partshelf/Acu-Rite-00592W-Manual.
Nov 17, 2011 | Acu-Rite Adagio Clock Radio
Need to know how to set time on ISTA SET 40009
Instructions
    • 1 Press and hold the "Alarm Set" button for five to seven seconds if you have an Insta-Set 40001, 44100 or 44200 model; the year will begin to blink when the clock is ready for adjustment. If you have an Insta-Set 40009 or 40018, hold the "DST" button for five to seven seconds (until the hour begins to blink).
    • 2 Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
    • 3 Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
    • 4 Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Read more: How to Change the Time on an Equity Insta-Set Clock ' eHow.com http://www.ehow.com/how_5657092_change-time-equity-insta_set-clock.html#ixzz1d1qIibS4
Nov 07, 2011 | Equity Time USA Insta-Set 40009 clock
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
How do you manually reset a Lacrosse Atomic Clock. Ours is always 4 hours behind and has not caught up. We already changed the batteries.
There are many LaCrosse atomic clocks. Which model do you have? Support for most is available here: http://www.lacrossetechnology.com/support/home.php . Use the drop down menu to select the model.
For the analog clocks, there is a manual set button on the back of the clock. Press the button and wait for the clock to advance to the correct time. Then make sure the correct time zone button has been pushed. Then make sure the clock is in a location where it can hear the signal overnight. (For best results stand the clock upright in a window.)
For WT-2165U travel alarm, press and hold Set to enter the setting function. Then select the time zone (with + or -) then press and release Set. Set the DST setting to on or off as needed, then press and release Set again. The next setting option is the snooze alarm duration. Press and release Set again to change the hour manually (+ to increase). Press and release Set again to set the Minutes. Correct the date (year, month, day, day of week) similarly. Then set the display to 12 or 24 hour time. Press and release Set to finish and exit the set functions.
For some of the digital clocks you can set the time manually by pressing and holding Set. First set the time display mode (12/24), then press and release Set again. Then set the hours, followed by Set and then the minutes. Continue through other menu options or just do not press any buttons for several (30) seconds.
On the digital clocks, the item being changed will flash.
To avoid interference with the signal reception, place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal.
I hope this helps.
Feb 03, 2011 | La Crosse Radio Controlled Atomic Clock
I have a lacrosse technology wall clock how do i set the time
You don't set the time. You set the Time Zone and it sets itself.
What model is YOUR clock?
This site lists several models of La Crosse wall clocks with downloadable instructions.
http://www.klockit.com/depts/AtomicClocks/dept-52.html
The link below is generic but there are specifc downloads for clocks with other features.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
Setting clock
It depends on the brand and model.
Normally it's a sequence like:
CLOCK > 1 > 2 > 3 > CLOCK
CLOCK > 1 > 2 > 3 > START
CLOCK > CLEAR > 1 > 2 > 3 > CLOCK
CLOCK > CLEAR > 1 > 2 > 3 > START
If not, please post a new inquiry with your correct brand and model.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 23, 2010 | Magic Chef MCD1311ST Microwave Oven
Tivoli model three clock problems
SELL! SELL! SELL! Yup the clock has bit the dust sell er and cut your losses.
May 12, 2009 | Tivoli Model Three Clock Radio
Centrios (121-9015) FM Radio Logo
71 people viewed this question
Top Centrios Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Centrios Audio Player and Recorder Expert? Answer questions, earn points and help others
