Question about Bunn 10 Cup Home Coffee Brewer
How to clean the coffee pot - Bunn 10 Cup Home Coffee Brewer
  • 43,501 Answers
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
Posted on Aug 25, 2010
Bloomfield coffee maker overflows, even with plain filter
The outlet of the cone filter holder is clogged. Normally its just a hole you can clean out but some units have a valve that is pushed up/open by your coffee pot. That valve may be clogged or if you changed the coffee pot it may not be opening due to the different pot. Clean valve or just remove it so the coffee will run into coffee pot.
Nov 13, 2013 | Lands Phones
How do you clean a metal coffee pot?
To clean your metal coffee pot you can pour boiling water into the pot and add a few drops of liquid dishwasher cleaner. Leave it to sit overnight and in the morning tip it out and rinse it out carefully before you use it.
Feb 25, 2013 | Home
Can I use citric acid to clean out the limescale from my coffee pot? It looks horrible and is starting to affect the taste of my coffee.
Limescale needs something stronger than basic dish soap to remove it. Citric acid and vinegar are both very good products for cleaning coffee pots. Using a ratio of about one part citric acid to 20 parts water, brew the pot of coffee as you normally would. After that, do another 2 cycles of 'brewing' using just plain water. This should clean your coffee pot out nicely. Good luck.
Feb 25, 2013 | Home
My coffee pot is black inside & using vinegar does not clean it
Use a coffee pot cleaner such as Dip-IT. Walmart sells a product in the coffee maker area that is for cleaning the coffee maker. It cleans the coffee pots too.
Feb 24, 2011 | Cuisinart DTC-975 Coffee Maker
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
How do i clean my bunn air pot coffee brewer?
Run a pot of half water and half vinegar through the coffee pot and you may need to repeat this process a couple times to get all the calcium buildup cleaned out of the pot. Hope this helps.
Jun 21, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee has a greasy taste
You will need to pull you coffee maker out and take the top off and clean inside the water tank. Someone has put coffee from pot of old cold pot of coffee back threw. or something loke this. just clean inside and out. clean coffee maker and pots. hope this helps
Have a cup on old saw
Aug 09, 2009 | Bunn VPR Coffee Maker
Bunn 10 Cup Home Coffee Brewer Logo
69 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
