Question about Texas Instruments TI-83 Plus Calculator
I just changed the batteries in my calc and now it won't turn on. Is there a reset button?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
There's no reset button. But TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries and turn the calculator on. (You may have to adjust the screen as described above.)
If that doesn't work, please append a comment to this post and we'll go on from there.
Posted on Aug 30, 2010
  • kakima Sep 02, 2010
    So, did that do it or not?
Sharp el 9300c
I took the EL-9300 apart to look for cold solder joints on the battery terminals. Found no bad connections. Make sure you remove all retaining screws.
Cleaned the pc board under the reset button. Cleaned the board under the slide switch that is actuated by the metal battery hold down clip. When you go to turn on the calculator install the hold down clip because it makes a connection to the pc board.
When I pushed the "On" button I got a down arrow. Push the "Reset" button when you get the down arrow. Various menus came up and I managed to reset the calculator.
Jun 06, 2013 | Office Equipment & Supplies
My calc wont turn on i changes batteries and back up battery, still it wont turn on.
Hi:
you calculator is on, you need to adjust the brightness , try 2nd up botton or down button this will darken the curser so you can see it than press some numbers and see if you can see them . okay
Oct 10, 2009 | Texas Instruments TI-84 Plus Calculator
A friend gave me a TI-86 graphing Calc. I wont turn on!!!
maybe try changing the small memory battery inside, I think its a cr1616 or cr1620. If this doesn't work use it as a paperweight.
Apr 23, 2009 | Texas Instruments TI-86 Calculator
TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/ti-cares@ti.com if you need specifics on getting the calc to take an OS upload given the state it's in."
Feb 24, 2009 | Texas Instruments TI-83 Plus Calculator
First time used in months
Check the batteries polarity.
Perhaps it needs a "reset", some calcs do have a "button" therefor, some do if you press the start button for some seconds.
Try to leave the calc overnight without any batt. inside.
Sep 19, 2008 | Texas Instruments TI-83 Plus Calculator
Casio Fx-82TL calc display problem
it seems the problem is on the lcd. technicians usually use soldering iron to apply heat to the cable connecting the lcd to its mainboard.
Sep 16, 2008 | Casio FX-115ES Scientific Calculator
My Ti83 silver edition will not turn on.
I'm not sure if this will help you patchesb7; it sounds like your calculator is having issues :(
This will help others whose calculators suddenly won't turn on anymore, even after changing the batteries.
Note:
This will return the calculator to the way it was when you got it out of the package. Any data or programs have stored since will be lost.
Step 1: Remove all four AAA batteries.
Note: You will have to hold down the CLEAR button while doing Steps 2 and 3. Do not let go until after you have pushed ON in Step 3. I found this easiest to do by holding the calculator upside in my left hand with my pointer finger holding the CLEAR button so the ON button was easier to access.
Step 2: Hold down the CLEAR button (located under the arrow keys) and reinstall the AAA batteries.
Step 3: Press ON button and then let go of both buttons. The screen should say the RAM has been cleared. Press CLEAR to continue.
Aug 24, 2008 | Texas Instruments TI-83 Plus Calculator
Darken screen!!!
reset your calc, press 2nd left right on simultaneously. it should work.
Apr 25, 2008 | Texas Instruments TI-89 Calculator
TI 84 Plus Silver Edition Wont Work
I tried blowing compressed air with a computer air duster into the I/O port. I do not know what this does but, it REALLY WORKS!!! My daughters TI-84 Plus Silver Edition is working fine.
Feb 08, 2008 | Texas Instruments TI-84 Plus Silver...
None of my buttons work except the ON button
Sounds like a possible short to me, But I don't have experience with that cause I have yet to test my calc with water if you know what I mean... The one thing that I can suggest is trying to connect with another persons calc and try the "send OS" command to see if that will reset your calc to a working state. Sorry to hear about the damage though.
-Saik0Shinigami
Feb 06, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
52 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
