Question about Magic Chef Refrigerators
Where is the defrost clock on this model? csd2122arw
  • 6,784 Answers
HI. The defrost timer will be located in the main control housing. You will need to disassemble that housing to gain access to it. The light shield will come off first, then you can disassemble the rest to access the timer.
Click here to view an exploded diagram of the housing. Your defrost timer will be labeled number 13 on that diagram.
Posted on Aug 25, 2010
DEFROST TIME CLOCK GE GSH25J, WHERE IS IT LOCATED?
Hello:
Your model does not have defrost timer, instead the defrost is controlled by Main control board located on the back of the fridge..
Part # WR55X10942
PS.. Most common defrost problem on this model is not the board. Its either defrost heater or defrost thermostat..
Jul 15, 2017 | GE Refrigerators
I changed the defrost timer on a cpf50c and lost my position tags on two wires. I need to find a technical manual with a wiring diagram.
L1 goes to 1-2 on Clock, L2 or Neutral to N on Clock, Defrost heater to 3 on Clock, Defrost Limit/Fan Delay to X on clock
Dec 09, 2010 | Nor-Lake Freezers
Is the ge tbx19 defrost clock continious or cumulative?
The timer will advance whenever the cold control is on. (when the compressor is running, or the timer has advanced into a defrost cycle) When the refrig is cold enough (and the timer has not advanced into defrost) the timer will not be advancing. A typical defrost timer will count up 8 hours of compressor run time before going into a 30 minute defrost cycle. (the run time and defrost time can vary greatly from model to model)
Jun 16, 2010 | GE Profile 19.0 cu. ft. Top Freezer...
True model gdim-26. runs fine unitl defrost then does not keep cold after defrost.
Hi, sounds like your defrost clock is stuck in the defrost mode. On most true boxes they have a paragon defrost clock with adjustable pins you can set the amount of cycles and duration of the defrost cycle. Find the clock and give it a turn in the direction of the arrow or cw. It will come out of defrost and start to freeze again. If it continues, you may need a new clock. Let me know what you find. Keep me posted. True boxes are top of the line
Sincerely,
Shastalaker7
Mar 23, 2010 | True 26 cu. ft. Commercial Freezer GDIM-26
Danby DFF8803W freezer keeps freezing up. What causes this?
Some models are a manual defrost. That meant every 3-4 weeks you must unplug it and let it defrost. These types usually have no fan in the freezer, instead it's a cold plate. If there is a fan in your freezer section it should automatically defrost. You might have a bad defrost clock, or a bad defrost heater.
Nov 02, 2009 | Danby DFF8803 Top Freezer Refrigerator
Evaporator fan of blast freezer not working? continnious showing (Defrost)in the display control,please help, any idea regarding this problem thanks...
On the Traulsen reach-ins, the evaporator fan on a freezer will shut off during its defrost cycle. If the the display is indicating defrost, sounds like it is stuck in defrost.Depending on model, most due have a defrost clock mounted near the t-stat or where it is easy to locate. Compressor is probably on top. They normally use a paragon 120 or 240 volt time clock. They have 12 and 24hr. clocks also. Find this clock and watch it to see if it is working and if you have a meter, check for power to it.The contacts may just be stuck in the defrost posistion. Try and rotate it in the direction indicated to see if it comes out of defrost and starts operating. You will find pins, about 4 screwed into the dial at certain times as 12 midnight, 12 noon,6am and 6 pm.This is when the unit goes into defrost mode.See if the arrow is pointing to a pin. If so, it is stuck in defrost and timer may be faulty. There is also a dial in center of clock normally set for 35 to 45 min. which is the Lenth of time it will stay in defost.No need to change this. I am sure you will find that the defrost timer is you're problem.
Good Luck, shastalaker7
Oct 29, 2009 | Traulsen RBC100 Blast Chiller Reach In...
Where is the defrost timer located
Most residential units have the defroster clock in the base of unit towards the rear. It will probably be attached to a bracket with 2 screws. 3 or 4 wires wil be coming off it. ;)
Aug 20, 2009 | Freezers
Possible frezzer sticking in defrost
The defrost clock may be starting to go bad. It will intermittently get stuck in defrost. The next time the unit warms try to locate this clock. Advance the knob and if the unit turns on you know the clock is getting stuck. :)
Apr 06, 2009 | Traulsen Reach in Freezer - G12010
Whirlpool refrigerator doesn't defrost model et18tkxjwoo
Your defrost clock or the defrost element. Check the clock first. A new one is about $30.00
Feb 25, 2009 | Whirlpool Refrigerators
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Refrigerators Logo
56 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
