Question about Sunbeam 2370 MixMaster Series Stand Mixer
The food processor driveshaft jumps out of engagement when feeding vegetables in. The slot on the end of the driveshaft does not appear worn, to my eye. But it does not snap onto the engaging crosspin down inside the drive port, it engages (and disengages) easily and freely. Should it "click" into place? Could the crosspin (which is very hard to see) be worn? If so, can it be replaced?
  • garryandj451 Aug 26, 2010
    The product model listed is not my product, which is Mixmaster MM1000. When I entered my product model, the programme reverted to the default Mixmaster 2370. I notified FixYa but received an e-mail that the product model cannot be changed to my model. Therefore, I do not think your remarks apply.
    There is no electrical wire involved. The food processor is driven mechanically by a driveshaft which inserts into a hole in the top of the mixer. A slot in the end of the drivesmethinhaft engages a crosspin down in the hole. But it engages easily, and when in use it pops up, makes a great noise, and does not drive the blade.
    Something went wrong with your reply, because I cannot understand instructions such as the following:
    "see if you can fine the loose wire i disc oust about if there is non the it"
    Thank you. --Garry Marnoch
  • garryandj451 Sep 04, 2010
    Original answer is not comprehensible. My followup comment has not been answered.
    Genius:
  • 1,417 Answers
what the problem of engages and disengage indicate from your explanation is that there have been a failure of wire that is apower supply problem .
but for the shaft that jump out from it position it can be replace back to it place
carefully unscrew the processor from the screw if any with a screw driver (technician tools) then first of all try to see if you can fine the loose wire i disc oust about if there is non the it then mean that the shaft have gone bad which will need a replacement to get a better one of it and the same size you will have to take the processor to the store that a technician store around you well you can get a good part that will be compatible or at the producer office or branch.
thank you and thanks for using fixya.
Posted on Aug 25, 2010
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/fp-12dc.pdf Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
When itry to make bread dough in the mixer, the bowl locking mechanism doesnt work properly and the bowl moves and top of mixer jumps around how can i fix this
You need to make sure that the hinge pin is tight, turn machine completely upside down and tighten the slotted screw up inside the pedestal. If that doesn't fix it you will need to check that the locking lever is properly engaging in the slot. You may need to "SLIGHTLY" file the slot in the pedestal that the lever engages into. If you go mad with the file you could wreck the slot.
Sep 13, 2014 | KitchenAid Kitchen Aid KSM150PSMY -...
Repair food processor
The safety switch is not being properly engaged by the bowl/lid assembly. One of them will be faulty and need to be replaced.
Sep 07, 2014 | Cuisinart Food Processor, 9-cup
Kitchenaid 12C food processor has power but motor does not engage
You might have someone check (and potentially replace) the motor brushes and the switch.
Aug 11, 2014 | KitchenAid Food Mixers
I have the fruit and vegetable strainer attachments to my Kitchen Aid Mixer. I was processing concord grapes, and the grape seeds and skins have gotten stuck between the white plastic auger and the metal...
Put the square auger end in a vise and lock it down, get a heavy terry cloth rag and wrap it around the cone and turn back and fourth by hand, (the cone is not strong enough to take any pressure from tools) until it starts to move, then keep turning back and forth while applying a lifting motion to the cone. That,s how I get mine apart when I get orange seeds stuck in it.
Sep 24, 2013 | KitchenAid Fruit and Vegetable Strainer...
Kitchenaid food processor
Take it back under guarantee, it's brand new.
Mar 31, 2013 | KitchenAid KFP0711 Food Processor White
Oil came from my mixer
You have a bad gasket in your mixer, the oil inside from KA is 6 oz. and the oil is due to separation, as KA uses a food safe vegetable based grease and after periods of non use it separates, liquids from solids, and leaks when the gasket seal goes. It is a messy fix but fairly easy, ereplacmentparts.com has a video on it. hope this helped
Feb 16, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
How to use potato slicer machine
Take the cover off end off mixer and slide in and lock in with locking Nut simples
Jan 17, 2013 | Hobart Nice Power Dicer Mixer Pelican Head...
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
H600t has a grinding sound when engaged
All you can do is take to top off and look inside. Look for damaged gears, shafts that move sideways slightly (or more than slightly) when power is applied, that sort of thing.
Also look for a worn gearshift. Be sure that it engages fully in each gear- observe and see how the mechanism works, there's an overrun clutch with dogs that can drag if the shifter is worn or out of adjustment.
There's not much to go wrong with a Hobart, they seldom fail and are generally easy to repair. Replace the grease while you're in there, if you don't like bearing grease call around and find some food grade grease, a lot of auto parts stores carry it now.
lp
Jan 16, 2011 | Hobart D300-6036 Mixer
Sunbeam 2370 MixMaster Series Stand Mixer Logo
32 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
