Question about Garden
I would like to know how to adjust my deck, the left front side wants to sit about an inch lower than the rest. Any ideas ? I have a Troy Bilt Pony
  • 10,865 Answers
Hello.
  • 1 Park the mower on a solid, level surface. Disconnect the spark plug wire, and remove the key from the ignition to prevent the mower from starting while you're adjusting its mower deck.
  • 2 Place work gloves on your hands to prevent from getting cut when coming into contact with the mower's blades. Put the mower deck in its highest possible position by moving the deck lift lever to the top notch.
  • 3 Position both blades so that they are perpendicular to the lawn tractor if making a side-to-side deck adjustment or parallel with the tractor if making a front-to-rear adjustment.
  • 4 Use a tape measure to measure both outside tips of the right and left blades if making a side-to-side adjustment. Use an adjustable wrench to partially unscrew the hex cap screw located on the left deck hanger bracket if the blades are not equidistant from the ground. Do not remove the hex cap screw.
  • 5 Use a wrench to rotate the adjustment gear behind the hex cap screw to balance the deck. Turn the adjustment gear counterclockwise to bring the side of the deck closer to the ground or clockwise to lift it from the ground. Measure both exterior blade tips to determine whether the deck is level or whether more adjustment is necessary.
  • 6 Use a wrench to tighten the hex cap screw on the left deck hanger once you have established that the deck is level.
  • 7 Measure how close the front and back of the blade tip are to the ground if making a front-to-rear deck adjustment. Proceed to the next step if the front tip is not 1/4 to 3/8 inches lower to the ground than the back.
  • 8 Loosen the jam nut on the stabilizer bracket's front face, which is also where the lock nut is located. Raise the the deck front by tightening the lock nut; lower the deck front by loosening the lock nut. Tighten the jam nut once you have completed the front-to-rear adjustment.
  • Posted on Aug 25, 2010
    Troy Bilt pony will not start
    no fire , sounds like your having a problem with one of the safety switches on mower deck ckt look under tractor but over mower deck for a loose or hanging wire bet it goes to a switch ?
    Nov 13, 2013 | Troy Garden
    I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
    One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
    The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
    Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
    I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
    I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
    Thanks for your question @ FixYa.com
    May 30, 2011 | Troy Garden
    Level 5 on the deck height is where I would want 3 to be. How do I raise the deck? I tried the front screw which just raises the front. The 3 holes on the rear end of the deck don't make any differnece...
    look under the mower like down below the seat , there should be a bolt on one or both sides ,this is for the back of the mower deac. If not ,raise the deck all the wau up and adjust by th front bolt
    May 26, 2010 | Troy-Bilt Pony Garden Tiller
    Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
    HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    I need a diagram to adjust/level the Deck on my 2006 Troy Bilt Lawn Tractor. Do you know where I can find one? Model 13AN77TG766
    The adjustment is on the left rear deck hanger. Loosen the 1/2 lock bolt in the center of the large nut, then turn the large nut with a adjustable wrench or socket, if you have one that big, clockwise or counterclockwise to raise or lower that side to equal the right side height.
    Jun 04, 2009 | Briggs & Stratton Garden
    Front wheels not aligned
    it sounds like your drag link is bent.look under the front.the rod connecting the two tires should be straight.if not,straighten it and slide a slightly larger piece of galvanized pipe over the rod to stop it from bending again
    Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
    Ineed the diagram for a 42 inch deck troy bilt
    We I disengage the blade belt always comes off its to loose I have had the number checked they say its the right belt but its so sloppy
    Apr 26, 2009 | Garden
    Troy bilt pony left side tine assembly fell off
    sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
    Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
    Wheel shaft seals on troy bilt pony 7 hp.
    If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
    Oct 20, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
    Garden Logo
    97 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
