I am attempting to reload Windows XP Home from the disc supplie when I purchased my Medion Laptop. I have reformatted the Hard Drive. When it gets to the bit where XP is installing devices the dreaded blue screen comes up saying a compability issue, As Windows is not fully loaded cannot get to safe mode to try and fix with Registry Mechanic etc. Help!
  • 1 more comment
  • Doug Olmstead
    Doug Olmstead Aug 25, 2010
    I'm afraid Reg MX will not fix this issue. what you are experiencing is a hardware conflict. the blue screen gives you a error code x000007e or something like that . look that error up on Microsoft.com there may be a solution. you may need to add addition video driver or something like that before you load windows. Medion is a UK company and there may be international limitation at play if you need help - I charge for repairs
  • terrance_c_e Aug 26, 2010
    Thanx for that I will put another hard drive in over the weekend. Where are you based?
  • Doug Olmstead
    Doug Olmstead Aug 27, 2010
    I am based in Rockford IL www.basetwosystem.com
    Sergeant:
  • 201 Answers
Have you got another hard drive to test against whether your hard drive is working properly.if not try re-installing windows again ensuring that you use the full reformat not the quick one.make sure you are selecting the drive that you are replacing ,c,.is usually the default number used.any probs get back to me.
Posted on Aug 25, 2010
My medion akoya laptop won't load past intel screen
This is a hard drive issue or windows have corrupt files, if you have the installation disc try and reload the operational system, if no change! have the hardware checked out at a computer repair store.
Apr 08, 2012 | Medion Computers & Internet
Have an older T23 IBM Thinkpad. Was running Malwarebyts which I just loaded on the system due to a problem at work and wonted to make sure i was ok at home. System ran for aprox 32 min and apeard to lock...
This is a possibility, the T23 is a very old laptop.
Normal 0 Check the BIOS to see if the hard disk is detected, if not open then re-seat the hard drive.
If the BIOS does not detect this hard drive, then the hard drive is probably faulty.
If it was me, I would not waste my time and money trying to get a new hard drive for this ThinkPad.
Disk drive manufacturers do not make small capacity hard drive anymore and the current range of hard drives won't work in your ThinkPad because the BIOS cannot support these hard drives.
Oct 02, 2010 | IBM ThinkPad T40 2373 Notebook
My 13 year old son laptop need be reset like new
There are a couple possible solutions to your problem. If the computer will still turn on and load windows, and I assume you are using Windows XP, you can try doing a system restore. To do this, go to Start, Programs, Accessories, System Tools, and select System Restore. If system restore is enabled, you should be able to choose a date in the past when the laptop was working properly and restore the computer to that date. If you want to completely reload windows, you will need a Windows XP installation disc. Load the disc in the CD or DVD player and reboot the computer. You should see a screen asking you to press any key to boot from CD, go ahead and press Enter. You will now enter setup where you can reformat the hard drive and reload windows XP. Follow the on-screen instructions to delete any old partitions, and then create a new partition and format it using NTFS. The windows XP installation will continue after the hard drive is formatted. If, when you reboot the computer with the installation disc in the drive, you are not prompted to boot from CD, you may need to reboot and press F2 or F12 to change the boot selection to the CD or DVD drive so it will load the CD first before it tries to load your original Windows installation.
Jul 18, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Have reformatted and am trying to reload xp on a
Probably a dirty or scratched disc. You can borrow another and still use your own serial number
Feb 27, 2010 | Microsoft Windows XP Home Edition
I reformatted my computer and i cant get drivers
If you have linksys hardware install the cd that came with hardware and get to linksys website and download latest driver. Reformatted cleans drive to zip data and you needed to reload XP to get it going so anything you installed after the system purchase you will have to reinstall.
Aug 29, 2009 | Microsoft Windows XP Home Edition
Hal.dll corrupt or missing
Does the Hard Drive have Windows on it? If not, install the Windows Me Floppy disk. Select Run With CD-ROM Support or RUN With Out CD-ROM Support. Any of the two. After it gets done loading. type the following. fdisk
It will ask you do you want to use extended Hard Drive use? Y/N
Press Y. Then you'll get a screen with 4 options. If Windows is on there type 4. And see what it says on your hard Drive.
If you wish to erase Windows and reinstall it, click 3. to delete the partition and it will ask to restart the computer.
Restart the computer and reload to the fidisk screen and press 1. and it Will install a partition "Not Windows" After the Partition is installed restart the Computer and remove the floppy. If it comes up saying No Operating System found. Then the Hard Drive is set to install Windows.
The cheapest Windows XP you can buy Is Home Edition for $99.98, witch some stores still sell, like BestBuy.
If you want to send the Laptop to me I can install Windows on it for you. I have Windows 95,98,ME,2000 Pro, XP Home, XP Pro and Vista Home Basic. Thats if you don't want to spend money on Windows. Just pay for shipping.
Dec 12, 2008 | IBM ThinkPad G40 2384 Notebook
Reformatting question
If you didnt get one you can go to the computers manufacturers website and tell (email) them that you would like to purchase one as it didnt come with your computer
Jul 05, 2008 | Microsoft Windows XP Home Edition
NO SOUND DEVICE FOUND AFTER RELOAD WINDOWS XP
hi reloaded windows xp on medion mim2220 laptop unable to find sound device to work sound for my laptop cant play any music can you help please
Feb 25, 2008 | Medion (40010998)
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
