Question about Maytag SkyBox MBV1976A Beverage Dispenser
Only goes to 58 degrees - Maytag SkyBox MBV1976A Beverage Dispenser
  • Maytag Master
  • 43,501 Answers
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a rel='nofollow' href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a rel='nofollow' href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a rel='nofollow' href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Posted on Aug 25, 2010
R22 unit running at 160/58. Took bulb out climbed to 61 on suction then right back to 58. Replaced txv. Charged to 220 head, suction stays at 60. Clean coil, no filter, good airflow. Ideas?????
Sounds like bad valves in the compressor.
A good indicator is how fast the pressure changes when you shut the compressor off. It should take several seconds for the suction pressure to rise. If it's immediate, then expect a bad valve.
Mar 07, 2016 | Heating & Cooling
Hi, my Samsung rs267lash freezer side only goes down to 58 degrees. What can I check to find solution please.
You will have to ask the retailer you bought it from they might know what the problem is. if it's not fixable you might have to purchase another fridge of your choice.
Jul 10, 2015 | Samsung Refrigerators
Why does my fridge g frm preset 34 degrees to 58 degrees for a few hours and then back to 34 degrees for a few hours and back and forth?
all fridge thermostats have a 10 - 15 degree differential between the cut in and cut out temperatures, your is exceptionally large hence needs to be replaced
Sep 12, 2014 | Refrigerators
The cooler side of fridge does not work properly. Why?
Brand name and model number would help. It should be inside the refrigerator section usually on the upper right wall.
Link to youtube videos about this problem is below. One or more of them should help with your problem.
Go to http://searspartsdirect.com/ and enter your model number. If your model is sold by sears you can see diagrams, parts lists, manuals and get help and order parts.
side by side refrigerator not cooling YouTube
Charged the a/c to spec but air wont drop below 58degs
A/C is all conditional upon ambient air temperature. If you are in a high heat area and getting 58 degrees fah., you are doing great. Take it on the highway and see how much further it goes down. The temp. inside is all relative to the outside temp.. That is the science of it. Let me know what your guage readings are and the temp where you are and I can tell you if you are doing good or great.
Jul 20, 2010 | 2001 Pontiac Montana
Our Kitchenaid KBFA25ERSS01 freezer suddenly does not stay at 0 degrees. Fluctuates between 2 degrees and 12 degrees.
Sounds to me like you could have some serious problems. What you're seeing could be either the result of faulty electronics (i.e. the thermostat) or an even larger problem with the refrigeration system itself.
About the only thing that I could think of that could be repaired by the user would be the door seals if those are leaking. Anything more intensive than that though and your best bet is to contact a service person.
Jul 29, 2009 | KitchenAid Refrigerators
Need to know the torque sequence and ft lbs for a 1998 chevy cavalir 2.2 liter thank you
I found two pieces of information, but no picture showing the sequence, but hopefully this will help.
Tighten bolt 1 to 63 N·m (46 lb ft).
Tighten bolt 2 to 58 N·m (43 lb ft).
Tighten bolt 3 to 58 N·m (43 lb ft).
Tighten bolt 4 to 63 N·m (46 lb ft).
Tighten bolt 5 to 63 N·m (46 lb ft).
Tighten bolt 6 to 58 N·m (43 lb ft).
Tighten bolt 7 to 58 N·m (43 lb ft).
Tighten bolt 8 to 63 N·m (46 lb ft).
Tighten bolt 9 to 63 N·m (46 lb ft).
Tighten bolt 10 (stud bolt) to 58 N·m (43 lb ft).
Then tighten all bolts an additional 90 degrees
For the 2.2L engine. First Pass Long bolts 46 ft. lbs Short bolts 43 ft. lbs Final Pass Tighten all bolts an additional 90 degree turn.
Jan 01, 2009 | 1998 Chevrolet Cavalier
Honeywell Digital Thermostat won't click on if temp is below 59
do you live there? if so here are the rules for setting back temperature: do not lower the temperature more than 8 degrees F from the temperature you want it when your there, setting it back for periods of less than eight hours is also somewhat futile. Due to laws of thermo-dynamics the heat required to recover from more extreme setbacks or shorter periods of time exceeds the savings acquired by taking said action. As to your question directly there are no reasons why your thermostat should not function at any setpoint temperature that it is allowed to set to (45 normally being the lowest) if it does not function below 58 degrees it has a failure and should be replaced before it fails completely. Suggest a Robertshaw or Braeburn brand thermostat, Honeywell quality has slipped over the past decade to unacceptable levels. Unless your considering a Hunter in which case buy another Honeywell.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Maytag SkyBox MBV1976A Beverage Dispenser Logo
20 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
