Question about Brother MFC 6490CW InkJet Printer
I keep on getting a wrong paper size error and I just added paper to both trays and didn't change anything.
I keep getting wrong paper size when I try to print to A4
Posted on Feb 14, 2011
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Why do I keep getting an error message when I try to print on plain paper?
try to check your document paper size settings. if your document is in pdf format, try to unchecked the select paper size automatically but it will not respond since it is dependent on the paper size setting of the document.
Jul 17, 2014 | Ricoh Aficio SP C811DN-DL Printer
In printer it showing Tray 1 ADD PAPER but [paper is added to the tray still it is showing that error so what to do ? give me the solution.
1.May be because of paper sensor.try to change it
2.may be you have given wrong paper size.u might have give wrong paper size.for ex for A4 paper u might have given some other size like a3. check this it will work for u
Jan 31, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
I am getting error message ' Load Tray 1, 024-910, Printer' but there is paper inside. Once we open tray and close, error message dissapears. Regards Melane
Make sure that after you add paper, that you tell the printer the right size paper. Chances are you accidently changed the paper size and the printer is letting you know that the "wrong" paper is in the tray. If you are using standard printer paper, be sure to change the paper settings back to "Letter"
Dec 08, 2010 | Dell 5110cn Laser Printer
Keeps giving me the error "Wrong paper Size"
The paper setting is either set to a differant paper size. In which case you can adjust this in the settings menu of the printer on the computer.
Or. You have the wrong paper tray inserted.
Aug 24, 2010 | Dell 924 All-in-One InkJet Printer
FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Jan 05, 2010 | Fuji DocuPrint C1110B Laser Printer
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
Paper Size Error
Check the paper size dial in the paper tray.Normaly the dail is turn to the wrong papersize.
Dec 16, 2008 | Office Equipment & Supplies
Xerox Phaser 7700 displays error 7-276
Here is the documentation on that error
07-276 TRAY 3 PAPER SIZE SENSOR BROKEN (TTM)
EXPLANATION
An abnormal AD value was detected from the Tray 3 Paper Size Sensor.
Refer to BSD: CH7.4 CH7.13A
Procedure
Set Tray 3 in the machine.
Between Tray Module PWB J548-11 (3T: J548-11 , TT: J548-11) (+) GND (-)
Is the voltage the same as that in the Tray 3 Paper Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) (+) GND (-)
Is the voltage the same as that in the Tray 3 Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-1 (3T: J820-1 TT: J820-1 ) (+)J820-3 (3T: J820-3 TT: J820-3) (-)
Is the voltage +5VDC?
Yes No
Using the wire network from Chapter 7, check the +5VDC circuits to Tray 3 Paper Size Sensor J820-1
(3T: J820-1 TT: J820-1 ).
(WN 7.3.6 +5VDC-2)
Check for malfunctioning paper guide, poor contact caused by bending in the projection that pushes the switch, and
if there is no problem, change the Tray 3 Paper Size Sensor. (PL16.1)
Check for cut wires, poor connections between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) and Tray Module
PWB J548-11 (3T: J548-11, TT: J548-11)
Change the following parts successively:
TRAY MODULE PWB (PL16.9)
MCU PWB (PL13.1)
ESS PWB (PL13.1 ).
Apr 26, 2008 | Office Equipment & Supplies
Brother MFC 6490CW InkJet Printer Logo
1,166 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
