Question about Hayward S220t Top Mount Pro Series Sand Filter 22" Tank Include Top Mount Valve
I have a haywood s220t top mount filter unit, when in filter select water shoots out the drain line any help would be great.
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
You need to replace the gasket inside the valve to stop the leak and then run the pool using just the main drain until you can get more water in. The gasket kit is pretty cheap and not to hard to replace. We can try to get you the part number if you can post the valve brand and model. You should be able to call any local pool store with the brand of filter and get the part you need without any trouble.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 25, 2010
How to change sand in sand filter top mount
Remove the flange at the top of the media canister to separate it from the pump housing. Make sure to keep the O-ring in a safe place or you'll have a big mess when you put it back together.
Mar 12, 2011 | Hayward S220t Top Mount Pro Series Sand...
I have an inground pool with a Hayward S220T Pro Series Sand Filter. During normal operation, I am getting sand in the pool, through the inlet vents. I am wondering what the problem could be. I suspect the...
You would be correct; replace them with part number SX220DA and you should be all set. If the sand is older than 3 seasons, replace it too while you have to empty the filter.
Aug 23, 2010 | Hayward S220t Top Mount Pro Series Sand...
When I turn it to filter, water comes out like I was backwashing it. It backwashes and rinses fine, but it is like the valve or something inside has not closed all the way when I go to run the filter...
John
Jun 16, 2010 | Hayward S220t Top Mount Pro Series Sand...
How do I change the sand in my Hayward S220t Top Mount Pro Series Sand Filter
un-screw the entire top valve unit. I would duct tape over the top of the riser pipe at the top.You do not want to get any sand inside that pipe. Turn upside downand rinse out completely. Add new sand remove duct tape and replace top valve unit
Jun 12, 2010 | Hayward S220t Top Mount Pro Series Sand...
Water is leaking from the backwash valve into the waste drain.
If you remove the six screws from the top of the dial and lift it out you will find a spider gasket in the base of the valve. This is probally your problem. If you pull this out and clean and dry the base you can spread some silicone on a new one and put back in place. Then replace the top and leave for a couple of hours and that should fix your problem.
Apr 28, 2010 | Hayward S220t Top Mount Pro Series Sand...
Motor humming but not engaging
The pump needs to be primed by adding water to the basket.If it still doesnt start it might need the a rebuild which usually involves replacing the bearings(cost about $150.00 NJ area).
Apr 22, 2009 | Hayward S220t Top Mount Pro Series Sand...
Hayward S220t Top Mount Pro Series Sand Filter 22" Tank Include Top Mount Valve Logo
Top Hayward Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hayward Garden Expert? Answer questions, earn points and help others
