Question about Canon MP610 Photo All-In-One Printer
My refilled cartridge doesn't seem to be recognised by my printer. Do these printers not accept refills?
    President:
  • 1,138 Answers
To let the printer recognized the refilled ink you must do the reset procedure to clear the error. Here's how to do it.
1. Disconnect power cord from the back of the printer.
2. Press and hold down Power button while plugging the cord back in.
3. While holding the Power button, press the Reset button twice
(The printer will display "Factory 1". Allow the printer to finish reading until the word "idle" appears, it will take sometime)
4. Disconnect the power cord.
5. Reconnect the power cord
6. Turn the printer on
If errors still persist, this one for finale.
1. Press and hold the Reset button.
2. Release the Reset button when the printer restart by itself.
Let me know if this procedure help you.
Please comeback and do rate this solution.
Thanks for using Fixya.
Posted on Aug 25, 2010
Epsom TX550W Doesn't recognise replacement cartridges
Are they official cartridges? If not, are they direct replacements for the Epson versions of the cartridges: Epson T0732/T0732N/73N Epson T0733/T0733N/73N Epson T0734/T0734N/73N
If they are, have they been refilled or bought fresh? If they have been refilled, have they been re-programmed? Have you updated your printer firmware recently?
May 08, 2011 | Epson Office Equipment & Supplies
Tip
Your refilled HP ink is not recognised by your printer.
Sometimes your printer won't accept your refilled cartridges although you have full ink & no leakage.
What you can do is to trick the printer software. Use another cartridge & refill it and later you can use the first one.
Another trick is to remove the CMOS battery to erase the error. ( its location varies from printer to printer ...a bit painful)
Please if you found the tips helpful please rate it. Thanks.
on Feb 18, 2010 | Office Equipment & Supplies
Printer not accepting the refill cartrage
Hi
when You refill cartridges
you must **** out all the air bubbles
from the sponges inside the cartridge
check this video how
in order to avoid overheating the printhead something that
destroys the cartridge and the printer can recognise it
the only think you can do is to replace the cartridge that can not
be recognised
Dec 25, 2010 | Office Equipment & Supplies
My printer doesn't recognise the new refill; and i can't seem to overide it to print. I tried a cheaper refill and then bought a genuine epson and it still doesn't recognise the replacement cartridge. ...
If this printer takes the Epson 69 cartridge you need to make sure the chip is replaced or reset on the refills you buy. I own a Cartridge World ink refilling store and I can't fill these cartridges yet because there are not replacement chips (that don't violate Epson patents) or a resetter for the chip. The chip communicates with the printer how much ink it thinks is left in the cartridge so you don't run it dry and ruin your printer. Once the chip says the cartridge is empty it will refuse to print until the chip is reset. It seems to me like you bought two refill sets from sellers that are scamming the consumer by not mentioning the chip problem. This is the main reason why I don't recommend internet refills is because it is really easy to take advantage of people. I would not buy refills until a reputable store like Cartridge World or Office Depot sells refills.
Jan 24, 2010 | Epson Stylus DX8400 All-In-One InkJet...
My hp printer c4580 won't accept refilled ink cartridges how do i do this rodney
> won't accept
Error-messages? What happens? What does not happen?
Did you refill the ink-cartridges yourself, or did you take it to a company that does the refilling?
Dec 11, 2009 | HP Photosmart C4580 All-in-One InkJet...
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
Lexmark X5495 printer will not accept refilled cartridge
The answer is " Every product like Lexmark, Hp etc is designed to use their own cartridges " so if the printer recignises refilled cartridges fine ...its ur good luck ...but if it does not recognise the cartridge then there is nothg which can help you
Nov 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Error 1203 cartridge error
There seems to be something wrong with the color cartridge that i had refilled. Even though the place that refills them says theres nothing wrong with it, the printer wont accept it. I just removed it :) thanks!
Feb 01, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Refilled cartridge not recognised by printer (canon PIXMA MP210)
I held down the stop butten for five seconds and now it seems to work fine. Perhaps this could help you.
Nov 14, 2007 | Office Equipment & Supplies
Canon MP610 Photo All-In-One Printer Logo
old marine
old marine
