Question about GPS
Mio Digiwalker Model No.. Mio 168 RS Manual - GPS
SOURCE: mitac mio 168 digiwalker
Hi, to replace battery, you need to undo the 4 screws hold the back casing. When these are removed you can open the back, revealing the battery. There is a black plug that pushes into a white socket on the pcb, with 4 wires coming out of it that goes to the battery. Pull this plug out and the battery then comes free. Hope this helps.
Posted on Jan 24, 2007
SOURCE: MIO DIGIWALKER NOT TURNING ON
hold the power button down for about 10 seconds. This will cause the thing to reboot....mine did the same thing. it will restart and should work ok.
Posted on Aug 04, 2008
SOURCE: Mitac Mio DigiWalker 168, Pocket PC PDA w/ GPS
mijn probleem is dat ik deze pc/pda in het nederlands wil zetten hoe doe ik dat
Posted on Sep 11, 2008
  • 5 Answers
SOURCE: I have a mio digiwalker c220 and it needs updated
use your pc softwhere disck . up load them
Posted on Jul 15, 2009
NEXTLAB
  • 58 Answers
SOURCE: Mitac Mio 168 Digiwalker cannot recon SD card
your SD might be and SDHC or larger that 4GB. try to use a FAT32 formatted SD, no bigger than 4GB
Posted on Sep 04, 2009
Testimonial: "what if its bigger than 4GB?(i used an 8GB card actually)...i'll try and let you know...thanks"
No gps signal on my mio digiwalker 168
Please try and reset the unit , check for fault in the settings . You can also remove the power and try a long reset and if after the boot there is no detection it is best to seek assistance specially if the unit is new as you can avail of free replacement warranty.
Nov 06, 2011 | Mitac Mio 168 Pocket PC
Sep 04, 2009 | Mitac Mio 168 Pocket PC
Need mio digiwalker c320 owners manual
it's on your c/d that came with unit or go to http://service.mio-tech.com/
May 08, 2009 | Mitac Mio C310 DigiWalker GPS Receiver
Broken 22 Pin,sync,charge,connector
Here's a solution for the broken socket on Mio 168 and Medion Micromaxx mdppc150 clones. Cheers
Mar 17, 2008 | Mitac Mio 168 Pocket PC
Freezing on start up
I have had a aproblem with my digiwalker Mio, which also was freezing up. The only way to sort it is a HARD RESET. The problem in my case appears to be due to the start up program initiating GPS/Tom Tom at the same time. good luck
Aug 28, 2007 | Mitac Mio 168 Pocket PC
Mitac mio 168 digiwalker
Jan 16, 2007 | Mitac Mio 168 Pocket PC
GPS Logo
112 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
