Question about Brother HL-2040 Laser Printer
I have a brother printer HL2040 lazer printer and the paper button keeps on flashing red. There is no paper jam any where and there is paper in the paper tray. What can I do?
  • 526 Answers
Check that the front and back cover are completely closed.
check for a paper jam in the back as well.
if you still dont see anything, you probably have a small piece of paper jammed in the sensor area somewhere in the printer,
Posted on Aug 26, 2010
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
HL2040 paper light blinking
Open the paper cassete and check if you have load paper in it.The second thing you can do is to open your printer front cover, remove the drum unit and check for paper jam inside the printer.
Oct 21, 2010 | Brother HL-2040 Laser Printer
Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Aug 07, 2009 | Brother HL-2040 Laser Printer
Brother HL-5050 paper flashing yellow
Have a look in the back of the machine. There could be a sheet in the fuser.
Oct 17, 2017 | Brother Office Equipment & Supplies
How to clear a paper jam from laser printer HL2040
Take the toner out of the fount and you will see a little piece of paper pull that out! Your good to go!
Mar 03, 2009 | Brother HL-2040 Laser Printer
My printer won't print. Can't get the Print light to turn off.
I downloaded the manual. It showed how to solve print light problems. There was some paper caught in the system.
It now works! Thanks for your concern.
Nov 18, 2008 | Brother HL 1670 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
73 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
