Question about Garden
What is the proper time to check the transaxle fluid? When it is cold, hot, engine running, or when it is off?
    President:
  • 1,545 Answers
Most likely when cold as all the oil will have accumulated and you can get a quite accurate reading.
Posted on Aug 25, 2010
Testimonial: "Thank you for your help, it was greatly appreciated, and helpful."
2002 Pontiac Grand AM how many quart of transmission fluid will it take to make it full.
DEXTRON III goes in. I would rec to start with 5 quarts. It may take up to about seven. And it will just go right into the dipstick tube. If you have no dipstick the fluid level ***** is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid. .
The engine must be running when the transaxle fluid level ***** is removed, or excessive fluid loss will occur. Since the actual fluid level is unknown, stand clear when removing the fluid level *****. Have a container ready to capture any lost fluid.
WARNING: Do not turn the engine off with the fluid level ***** removed as you can be injured by hot transaxle fluid being expelled out of the fluid check hole.
Mar 31, 2016 | 2002 Pontiac Grand Am
Transmission oil coming out the funnel
If you mean it is coming out of the fill/dipstick tube, then quit driving this car. You will trash the transmission, if it hasn't already happened. Usually when this happens the transmission cooler inside the radiator has busted, and is pumping coolant into the transmission. Then again I have seen some people just overfill it to the extreme. But either way it needs to be checked. This involves dropping the transmission oil pan.
Aug 08, 2011 | 2002 Ford Taurus
Need easy way to take off transmission fluid cap.Trying to check fluid.
Hello Eddie.
Checking the fluid level on these cars isn't easy. Not one of the Generals best ideas. There isn't a dipstick under that cap. The fluid level is checked by removing a screw on the side of the transmission while the car is running and sitting level.
This makes it tricky to do for the average do-it-yourselfer as you not only need to jack up the front of the car but the back end to keep it level. Probably a vain attempt to get the cars back into the dealers shop.
Anyway, here is the book procedure.
The fluid level screw is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid.
Inspect
The fluid level should be checked when the transaxle is near Room temperature or at 40°C (104°F) .
CAUTION: Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of transaxle fluid to exhaust pipe.
The engine must be running when the transaxle fluid level screw is removed, or excessive fluid loss will occur. Since the actual fluid level is unknown, stand clear when removing the fluid level screw. Have a container ready to capture any lost fluid.
WARNING: Do not turn the engine off with the fluid level screw removed as you can be injured by hot transaxle fluid being expelled out of the fluid check hole.
  1. Let vehicle idle for three to five minutes with accessories off.
  2. Apply brake
  3. Move shift lever through all gear ranges, pausing three seconds in each range.
  4. Place shift lever in Park. Important: Vehicle must be kept level on the hoist.
  5. Raise vehicle on hoist.
  6. Place oil container under fluid level screw.
  7. Remove the fluid level screw with the engine running at idle.
  8. Fluid level should be at the bottom of the fluid check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the fluid check hole when the fluid level screw is removed. If fluid drains through the fluid check hole, this transaxle may have been overfilled. When fluid stops draining, the fluid level is correct and the fluid level screw may be installed. If fluid does not drain through the fluid check hole, the transaxle fluid level may be low. Proceed to ADDING TRANSAXLE FLUID.
  9. Install fluid level screw. Tighten 12 N.m (106 lb in)
  10. Lower vehicle.
  11. Shut off engine. Adding Transaxle Fluid: With the engine running, add fluid at the vent cap location in half liter (1 pint) increments until fluid drains through the fluid check hole. Allow the fluid to finish draining through the fluid check hole.
  1. Install fluid level screw. Tighten 12 N.m (106 lb in)
  2. Lower vehicle.
I hope this helps you along.
Thank you for using FixYa.
KL
Nov 19, 2010 | 2000 Pontiac Grand Am GT
Check automatic transmission fluid level 2004 Pontiac grand am
TRANSAXLE FLUID CHECKING PROCEDURE
Inspect
  2. Apply brake
  1. Raise vehicle on hoist.
  2. Place oil container under fluid level screw.
  3. Remove the fluid level screw with the engine running at idle.
  4. Fluid level should be at the bottom of the fluid check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the fluid check hole when the fluid level screw is removed. If fluid drains through the fluid check hole, this transaxle may have been overfilled. When fluid stops draining, the fluid level is correct and the fluid level screw may be installed. If fluid does not drain through the fluid check hole, the transaxle fluid level may be low. Proceed to ADDING TRANSAXLE FLUID.
  5. Install fluid level screw.
Tighten 12 Nm (106 lb. in.)
  1. Lower vehicle.
  2. Shut off engine.
  1. Lower vehicle.
Oct 20, 2010 | 2004 Pontiac Grand Am
How do I check the transmission fluid on a 2009 Dodge Journey with the 3.5 liter engine. There is no transmission dipstick.
below is info from the owners manual. I do not have a repair manual, but you may be able to buy one that would say how to check the transmission fluid on the 3.5L. It sounds like they don't expect you will need to check it.
Fluid Level Check - Vehicles with 3.5L Engine
The automatic transaxle has no dipstick and is dealer
serviced only.
Fluid Level Check - Vehicles with 2.4L and 2.7L
Engines
Use the following procedure to check the automatic
transaxle fluid level properly:
1. Park the vehicle on level ground.
2. Run the engine at curb idle speed for a minimum of 60
seconds.
3. Apply the parking brake fully.
4. Place the shift lever momentarily in each gear position
ending with the lever in PARK.
5. Wipe the area around the dipstick clean to eliminate
the possibility of dirt entering the transaxle.
6. Remove the dipstick and determine if the fluid is hot
or cold. Hot fluid is approximately 180°F (82°C), which is
the normal operating temperature after the vehicle is
driven at least 15 mi (24 km). Hot fluid cannot be held
comfortably between the fingertips. Cold fluid is at a
temperature below 80°F (27°C).
7. Wipe the dipstick clean and reinsert until seated. Then,
remove dipstick and note the reading.
a. If the fluid is hot, the reading should be in the
crosshatched area marked "HOT" (between the upper
two holes in the dipstick).
b. If the fluid is cold, the fluid level should be between
the lower two holes in the area marked "COLD."
If the fluid level is low, add sufficient fluid through the
filler (dipstick) tube to bring it to the proper level. Do not
overfill.
Oct 04, 2010 | 2009 Dodge Journey
Where is the dipstick to check the transmission fluid?
LEVEL CHECK Check the automatic transaxle fluid level at least every 15,000 miles or 12 months. The dipstick can be found on the left (driver) side of the engine compartment. The fluid level should be checked only when the transaxle is hot (normal operating temperature). The transaxle is considered hot after about 20 miles of highway driving.
  1. Start the engine, set the parking brake, and put the transaxle selector lever in the P position.
  2. Move the selector lever through all the positions and return to the PARK position. DO NOT TURN OFF THE ENGINE DURING THE FLUID LEVEL CHECK.
  3. Remove the dipstick, wipe it clean and then reinsert it firmly. Be sure that it has been pushed all the way in. Remove the dipstick again and check the fluid level while holding it horizontally. With the engine running, the fluid level should be in the cross-hatched area.
  4. If the fluid level is below the crosshatched area (engine hot), add MERCON® III automatic transaxle fluid through the dipstick tube. This is easily done with the aid of a funnel. Check the level often as you are filling the transaxle. Be extremely careful not to overfill it. Overfilling will cause slippage, seal damage and overheating. Approximately 1 pint of ATF will raise the fluid level into the cross-hatched area. The fluid on the dipstick should always be a bright red color. If it is discolored (brown or black), or smells burnt, serious transaxle troubles, probably due to overheating, should be suspected. A qualified technician should inspect the transaxle to determine the cause of the burnt fluid. Fig. 1: Automatic Transmission dipstick location - Continentals 93141p13.jpg
    Fig. 2: The dipstick is easy to read and well marked. Do not add if level is in the crosshatch area 93141p12.jpg
Sep 18, 2010 | 1996 Lincoln Town Car
The transmission is not changing speeds and remained on the pace and one within 60 miles? I need your help
you have a fault in the transaxle electronic controls. check the fluid level in the transaxle first if it is low add fluid, check throttle valve cables to make sure they are free and not binding. check them when they are cold and again when they are warm, they may malfunction when the engine is hot. also check the shift linkage. hope this will help!!!
Apr 07, 2010 | 2005 Dodge Grand Caravan
Craftsman model 917-258870 can the trans fluid be changed.There seems to ba a filter on the trans.
TRANSAXLE COOLING
The
fan and cooling fins of transmission should be kept
clean to assure proper cooling.
Do not attempt to clean fan or transmission while engine is
running or while the transmission is hot. To prevent
possible damage to seals, no not use high pressure water
or steam to clean transaxle.
, Inspect cooling fan to be sure fan blades are intact and
clean.
o inspect cooling fins for dirt, grass clippings and other
materials° To prevent damage to seals, do not use
compressed air or high pressure sprayer.
TRANSAXLE PUMP FLUID
The transaxle was sealed at the factory and fluid maintenance
is not required for the life of the transaxle. Should
the transaxle ever leak or require servicing, contact your
nearest authorized service center/department.
Jul 12, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No tranny dipstick to be found ANYWHERE!!!!!!!!!
The fluid level screw is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid. Inspect The fluid level should be checked when the transaxle is near Room temperature or at 40°C (104°F) . CAUTION: Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of transaxle fluid to exhaust pipe. The engine must be running when the transaxle fluid level screw is removed, or excessive fluid loss will occur. Since the actual fluid level is unknown, stand clear when removing the fluid level screw. Have a container ready to capture any lost fluid. WARNING: Do not turn the engine off with the fluid level screw removed as you can be injured by hot transaxle fluid being expelled out of the fluid check hole. 1. Let vehicle idle for three to five minutes with accessories off. 2. Apply brake 3. Move shift lever through all gear ranges, pausing three seconds in each range. 4. Place shift lever in Park. Important: Vehicle must be kept level on the hoist. 5. Raise vehicle on hoist. 6. Place oil container under fluid level screw. 7. Remove the fluid level screw with the engine running at idle. 8. Fluid level should be at the bottom of the fluid check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the fluid check hole when the fluid level screw is removed. If fluid drains through the fluid check hole, this transaxle may have been overfilled. When fluid stops draining, the fluid level is correct and the fluid level screw may be installed. If fluid does not drain through the fluid check hole, the transaxle fluid level may be low. Proceed to ADDING TRANSAXLE FLUID. 9. Install fluid level screw. Tighten 12 N.m (106 lb in) 10. Lower vehicle. 11. Shut off engine. Adding Transaxle Fluid: With the engine running, add fluid at the vent cap location in half liter (1 pint) increments until fluid drains through the fluid check hole. Allow the fluid to finish draining through the fluid check hole. 1. Install fluid level screw. Tighten 12 N.m (106 lb in) 2. Lower vehicle.
Jun 05, 2009 | 2004 Chevrolet Malibu
Location of transmission (automatic) dipstick
You DO NOT have one.
There is a small bolt/plug in the transmission above the pan that needs to be removed. The fluid will run out if it's overfilled. The transmission needs to be at room temperature or a little warmer to check the level.
Inspect:
The fluid level should be checked when the transaxle is near Room temperature or at 40°C (104°F).
  2. Apply brake
  10. Lower vehicle.
  1. With the engine running, add fluid at the vent cap location in half liter (1 pint) increments until fluid drains through the fluid check hole. Allow the fluid to finish draining through the fluid check hole.
  2. Install fluid level screw. Tighten 12 N.m (106 lb in)
  3. Lower vehicle
Mar 23, 2009 | 1996 Chevrolet Cavalier
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
