Question about Linksys EtherFast Cable/DSL Router
I am unable to change the Lan ip address - Linksys EtherFast Cable/DSL Router
  • 104 Answers
Update firmware and try again. I take it you are trying to modify your LAN Subnet. from 192.138.1.0 to 10.10.10.0 something like that?
Posted on Aug 25, 2010
Can i renew/release the rooter ip address?
The WAN IP address of your router is assigned by your provider (TelCo, CATV provider, etc.). Most IP addresses are dynamic - which means they can change at any time without notice. When this actually happens is determined by them. It us not unusual to have the same IP address for months at a time however. There is not really something that you can do to make it change outside of contacting them specifically to have them do this for you.
LAN address changes are easier - and it is a process you can perform yourself. Do you need instructions for that? Keep in mind that changing a LAN address will not restore connections to a site that has blocked your IP. They have marked your WAN IP and no connection from the local area network (LAN) in your house will be able to connect.
Oct 23, 2015 | Edimax Network BR-6675ND Wireless...
How to reset Barracuda 330 link balancer?
The Barracuda Link Balancer is assigned a default LAN IP address of 192.168.200.200. You can change this IP address in one of three ways:
  • In the web interface, go to the BASIC > IP Configuration page.
  • Connect a VGA monitor and a keyboard to the back of the Barracuda Link Balancer. Use the serial console. (username admin, password admin)
  • Press the RESET button on the front panel.
Pressing RESET for five seconds sets the LAN IP address to 192.168.200.200. Pressing RESET for eight seconds changes the LAN IP address to 192.168.1.200. Pressing the button for 12 seconds changes the LAN IP address to 10.1.1.200. You will notice the three LEDs on the front panel flash at the same time intervals.
Mar 10, 2014 | Barracuda Link Balancer 330 with 1-Year...
Can't find IP address 192.168.1.2
Your IP address 192.168.1.2 is a Local IP address. Local(Computer) IP address ranges from 10.0.0.0 to 10.255.255.255, 172.16.0.0 to 172.31.255.255, 192.168.0.0 to 192.168.255.255. Normally you can login the Local IP address within a single building (or) campus using LAN. If you need to access around the world, it should be a Public(Network) IP address. To check your Network IP address, visit IP-details.com .
Apr 16, 2013 | Zyxel Wap3205 Wireless N Access Point -...
Unable to ping static IP from remote desktop when
Does PING works on the same location where Camera's are located?
Usually, RDP connections uses the same PC on LAN and that should work fine. Please check Camera's configuration; make sure they have valid IP address, SM, Default gateway and DNS servers. Make sure that PC with enabled RDP can PING computers on the LAN either by IP address or Computer name. Make sure they're part of the same WORK GROUP.
Hope this helps! Please provide additional information so I can further assist you.
Mar 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
How can I change the lan IP address?
Logon to the wireless router:
Default:
Username: (leave blank)
Password: admin
The first screen to appear is the setup screen.
You can chang ethe LAN IP address here and press [Save] then [Exit]
Thye default IP LAN address is 192.168.1.1
You must use a class C address for the LAN side of the router.
And all of your network devices (PC's) must be on the same "network":
Two examples:
Router address is 192.168.1.1
PC's must be in the range: 192.168.1.2 thru 192.168.1.254
Router address is 192.168.5.12
PC's must be in range: 192.168.5.1 thru 192.168.5.254 (except 5.12)
Oct 11, 2009 | Linksys WRH54G Wireless Router
How do i change my lan IP so my router works
Hi!
Start by opening up a web browser (it doesn't matter if it can get to the internet or not, as long as its from a PC connected to the router) and, assuming the LAN address is still the default, goto the address "http://192.168.2.1" click on "login" and you will be prompted for a password.
Again, assuming everything is still default the password is not set and you can just click "Submit."
On the left side you will see a menu, underneath LAN click on the "LAN Settings" link. You will be presented with a page were you can set a new IP address for the router. Once you change the IP and click "Apply Changes" the IP of the router will be changed. Once the device finishes restarting you will now have to use the new IP address you just entered, in you browsers address bar instead of 192.168.2.1, in order to see and configure the settings of your router.
Hope this helps! Here is a link to the manual for product incase you get stuck. The juicy stuff you want is on page 33.
Mar 26, 2009 | Belkin (F5D5231-4) Router
Unable to get a connection limited or no connectivity
hi
if u have lan problem u required your proper ip address .
also if your system ip address or computer name are same in other system in lan u got this problem.
so change your ip address and system name .
Mar 07, 2008 | Computers & Internet
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
After changing LAN IP, can not access setup page
If using DHCP, reboot your machine or release and renew the IP on the network card. If using static IP addresses, change the computer's IP address to match the new segment and remove the old default gateway and replace with the new LAN IP.
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Linksys EtherFast Cable/DSL Router Logo
18 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
