Question about Maytag M7Y15F2A Air Conditioner
My air conditioner turn off itself and the degrees on the ac would not go pass 31 degrees n its blew no kool air
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
What would cause my emerson quiet kool air conditioner 10GC13-L to keep tripping the breaker?
It probably has something shorted to ground or the compressor or motors are stuck causing a high amperage problem. The breaker is probably fine but it also could be weak but normally its the compressor or a component has faulted to the compressor. If the unit immediately trips breaker its probably shorted to ground. If the unit struggles to start and a few seconds pass before it trips then it may be a component fault.
Jun 09, 2015 | Emerson Quiet Kool 10GV13 Air Conditioner
I need a master control knob. I don't know the model number of the Emerson Quiet Kool air conditioner.
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Jul 13, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
We need one purhcase emerson window ac. Plant send contact details. In noida & New delhi
R.S.AIRCONDITIONER.
Mr Surender +(91)-9818551447 Shop No-5,Sharma Mkt,, Nr B Blk,Mother Dairy,Sec-31, Noida, Noida - 201301
HELPFUL?
Dec 27, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
Emerson quiet kool model.eqk 1350 f serialo 20e 808320 wont heat, does it have an element? where is it located?
I looked up the model number parts
Their does not appear to be a heating element associated with this ac nor a reversing valve so I don't think it has a heat feature. You could mount it backwards and heat an area. That would look weird.
Apr 29, 2010 | Emerson Quiet Kool 6GC53 Air Conditioner
Air conditioner turned itself on to 22 degrees.
If it got to 22 degrees the Ac unit should have self destructed. What brand and model is that unit?
I think I would love to have one here in Georgia.
Aug 21, 2009 | Royal Sovereign ARP-4012 Portable Air...
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Ac has a loud hard bang when compresser kicks in
The internal motor mounts for the compressor are broken, that is the loud banging.
At 17, new one is more energy efficent.
May 04, 2009 | Emerson Quiet Kool 12GJ14 Air Conditioner
Thermostat window ac turns unit on and off 8 degrees above se
the unit may be drawing the cool air it just released back into itself,plus the air close to the unit may be a little cooler than the air in the rest of the room.
Mar 19, 2009 | Kenmore 72059 Air Conditioner
Emerson Quiet Kool A/C Filter
If you know where to find a filter for a Emerson Quiet Kool--Model # 18DD4H-EE
Serial # 21A 927552 Please let me know
beverleyed@yahoo.com
Thanks
Ed Beverley
Jun 07, 2008 | Emerson Quiet Kool 10GV13 Air Conditioner
Maytag M7Y15F2A Air Conditioner Logo
149 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
