Question about Garden
Regulator sticks and will not heat properly. Can they be cleaned or lubricated to function again.
  • 43,501 Answers
I have lubed a regulator with WD-40 and it has worked for a long time after that...will not guarrenttee that it will work but it could be worth a try...
heatman101
Posted on Aug 25, 2010
What is the function of motivation of lubricating oil?
1: the lubrication oil supply continuously the friction surface of each part,forming a lubricating oil film, reduce the parts of the friction, wear and power consumption.
2 cooling effect: the lubricating oil flows through the part surface can absorb the heat and the heat back into the oil pan scattered into the atmosphere,plays the role of cooling.
3 clean: lubrication system through the lubrication oil flow, the parts of the surface of the abrasive washing down, back to the crankcase.
The 4 seal: seal the gap between the cylinder wall and piston, piston ring and ring groove.
5 anti corrosion: to prevent or reduce the component corrosion and chemicalcorrosion.
6 when the engine cylinder pressure rise sharply, suddenly increasing the piston, connecting rod and a shaft bearing load, the load of the transferlubricated bearings, the impact load to bear the receive buffer
source: obd2 tool car diagnostic tool auto diagnostic scanner
Nov 22, 2013 | Cars & Trucks
I have replaced the power window regulator clips several times on a 2003 Pontiac grandam and within 2 weeks these clips are breaking again and need to be replaced. During the two weeks the window will...
Hi Seijj, It sounds to me as though alignment is your problem. Disconnect the regulator and other mechanisms from the window and operate the movement by hand to find out where its sticking or becoming tight. When you do rectify that problem and reassemble. Regards John
Apr 28, 2012 | 2003 Pontiac Grand Am
How to install a fuel presure regulator on a 1998 chevrolet tahoe
Fuel Pressure Regulator - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Relieve fuel system pressure.
  3. Disconnect the ignition coil.
  4. Remove the upper intake manifold.
  5. Disconnect the vacuum line to the regulator.
  6. Remove the snapring from the regulator housing.
  7. Place a towel under the regulator to absorb any spilled fuel and remove the pressure regulator from the fuel rail socket.
  8. Remove the pressure regulator from the fuel rail.
  9. Remove the pressure regulator O-ring filter, O-ring backup and O-ring and discard them.
Fig. 1: Exploded view of the pressure regulator assembly-MFI systems
To install:
  1. Before installing the O-rings, lubricate them with clean engine oil and install them on the regulator inlet as a complete assembly.
  2. Install the snapring retainer into the slot on the regulator housing.
  3. Connect the vacuum line to the regulator.
Ensure that the retainer is properly seated in the slot in the regulator housing. Pull on the regulator to make sure that it is properly seated.
  1. Connect the negative battery cable.
  2. Turn the ignition ON for 2 seconds and then turn it OFF for 10 seconds. Again turn the ignition ON and check for leaks.
  3. Install the manifold plenum.
Hope this helps.
Aug 02, 2011 | 1998 Chevrolet Tahoe
Giotto Aluminum Tripod # 9160 - legs sticking - took legs apart, cleaned but did not lubricate - still sticking.
Call us at 800 735-4373 regarding serving Giottos tripods and for our address to get this properly repaired. It does not need lubrication.
Apr 27, 2011 | Giottos Photography
Im gonna rplace the fuel pressure regulator. In the haynes manuel it says that you need to remove the fuel rail. Ive asked a few people and they said they dont think it is necassary it is an 03 impala. ...
Not sure why Haynes says to do that. below is instructions from autozone.com, and none of the engines require the fuel rail to come off. That said, if you have the 3.4, you may need to pull the upper intake manifold.
Removal & Installation The need to work as cleanly as possible cannot be over-emphasized. Even the smallest amount of dirt, if allowed into the fuel pressure regulator and/or the fuel rail, will find its way to the fuel injectors. The nozzle openings of the injectors are very small. Keep hands and tools clean. Clean the areas to be disconnected with a suitable solvent. Carefully cover open fittings and connections to keep out foreign material. Dirt in the injectors almost guarantees a clogged fuel injector and engine performance problems.
3.4L (VIN E) Engines
  2. Relieve the fuel system pressure.
  3. Remove the upper intake manifold assembly.
  4. Disconnect the vacuum line from the pressure regulator.
  5. Remove the regulator retaining screw and remove the retainer bracket. Using a clean shop cloth to catch fuel spillage, carefully pull the regulator from the fuel rail. Twist the regulator slightly while removing to ease removal. Discard the O-ring.
    Fig. Exploded view of the fuel pressure regulator mounting-3.4L (VIN E) engines
To install:
  1. Clean all parts well. DO NOT use shop compressed air to test or clean a fuel pressure regulator. Clean the fuel pressure regulator screen, if necessary. DO NOT immerse the fuel pressure regulator in a solvent bath or it will be damaged.
  2. If the filter screen has been contaminated, it should be removed and the pressure regulator replaced.
  3. Lubricate a new pressure regulator O-ring with clean engine oil and install on the regulator inlet.
  4. Install the fuel return pipe to the regulator.
  5. Install a new retainer and spacer bracket into the slot on the fuel rail and install the pressure regulator to the fuel rail. Tighten the fuel return line nut to 13 ft. lbs. (17 Nm).
  6. Connect the vacuum line to the pressure regulator and install the retainer screw. Tighten to 76 inch lbs. (8.5 Nm).
  7. Inspect and verify that the retainer and spacer bracket is engaged in the slots in the fuel rail. Grasp and pull on the regulator to ensure that it is properly seated.
  8. Install the upper intake manifold.
  9. Connect the negative battery cable.
  10. Inspect for leaks using the following procedure:
    1. Turn the ignition switch to the ON position for 2 seconds.
    2. Turn the ignition switch to the OFF position for 10 seconds.
    3. Turn the ignition switch to the ON position again.
    4. Inspect all areas for fuel leaks.
3.8L Engines
  3. Clean any dirt from the fuel pressure regulator retaining ring.
  4. Remove the vacuum hose from the pressure regulator.
  5. Remove the snaprings. Twist the regulator slightly and pull the pressure regulator from the fuel rail. Use a shop towel to catch fuel spillage as the regulator is removed.
  6. Remove the O-rings and O-ring back-up.
To install:
  3. Lubricate the new pressure regulator O-rings with clean engine oil. Install the O-ring back-up, the large O-ring and then the small O-ring. Install the pressure regulator and secure with the snapring.
  4. Attach the vacuum hose.
  5. Connect the negative battery cable.
  6. Inspect for leaks using the following procedure:
To install:
Mar 16, 2011 | 2003 Chevrolet Impala
How to change a fuel pressure regulator in a 1997 pontiac grand prix
GM Century/Lumina/Grand Prix/Intrigue 1997-2000
Fuel Pressure Regulator - Removal & Installing
The fuel pressure regulator is a diaphragm-operated relief valve with fuel pump pressure on one side and regulator spring pressure and intake manifold vacuum on the other side. The regulator's function is to maintain a constant fuel pressure across the injectors at all times. The pressure regulator compensates for engine load by increasing fuel pressure as engine vacuum drops.
The fuel pressure regulator is serviced as a separate component. When servicing the pressure regulator, make sure that the O-ring back-up, large O-ring, filter screen and small O-ring are properly positioned on the pressure regulator.
44dcbf8.jpg Fig. Cutaway view of a typical fuel pressure regulator
3.1L and 3.4L (VIN E) Engines
  2. Relieve the fuel system pressure using the procedures found in this section.
  3. Remove the upper intake manifold assembly. Please see .
Fig. Exploded view of the fuel pressure regulator mounting-3.1L and 3.4L (VIN E) engines
To install:
  8. Install the upper intake manifold. Please see .
    • Turn the ignition switch to the ON position for 2 seconds.
    • Turn the ignition switch to the OFF position for 10 seconds.
    • Turn the ignition switch to the ON position again.
    • Inspect all areas for fuel leaks.
Other size engine can find in autozone.com (free register).
Hope this help (remember rated this).
Feb 08, 2010 | 1997 Pontiac Grand Prix
Need to replace fuel regulator on 96 chevy c1500
the regulator is part of the injector block. You will need to pull the upper plenume to gain acess to it.
Oct 11, 2009 | 1996 Chevrolet C1500
Don't have power to my front door windows.
Are you sure there is no power or is the problem that they just don't open? These vans have problems with sticking motors and windows. Mine stick all the time. One time, I took off the door panels, tested everything and there was both power to the motor and a functioning motor unit. I lubricated all the mechanisms and window channels and they worked properly for about two years. Lately they have begun to stick again. If I rock the window switch back and forth rapidly for about 10 seconds, they free up and function normally for about a week. If I'm wrong and you have metered out the plugs to discover no power, check the fuse.
Aug 01, 2009 | 1999 Ford Windstar
My playstation 3 analog sticks are becoming more stiff and are sticking in every position except the centre, which causes major problems when trying to stay still in games.
Yeah my controller started sticking up and not centering properly when released. I tried everything to clean it up but nothing worked untill I went to the local electronics store and got some contact cleaner with lubricating oil. (MG Chemicals - Nu-trol contact cleaner with special lubrication oils) Open the controller ( see youtube) the analog sticks cannot be taken apart but if you push the stick up you can squirt the base and work the cleaner/lube into the base. I squirted a bit on all 4 sides (left, right, up , down) working it in making a circular motion with the stick. Worked quite well and is the only thing so far that works at all. These seem to be sealed units (the sticks) with no way to open the business end to clean up the contacts. I put a toothpick under the tracing sheet to help with evaporation of the cleaner. Hope this helps.
Regards, Mike in Victoria
May 20, 2008 | Video Game Consoles & Games
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
