Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Have two Fisher&Paykel DD603 diskdrawers. They work great except the top one will not dissolve the detergent. It gets wet, but stay in the little tray. I've tried different detergents, different amount in the tray and cleaned it to where it was bone dry. The amount of water is good - gets the dishes clean without the detergent. The bottom one does not have this problem. I switched the spray arm and still I have the same problem. Any ideas?
  • Fisher and P... Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a rel='nofollow' href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a rel='nofollow' href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Posted on Aug 25, 2010
Testimonial: "Thank you, heatman101 - I've looked at all your suggestions and will go from there."
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Fisher paykel model dd603 - won't drain
Depends on Whether or Not you had the unit Professionally installed, The Drain Hoses are Designed to Stay their extra long Length, they act as a u-tube system using the center of gravity to help drain the unit, if you've cut them to short the water simply is unable to go up the lines because the drain pump is not strong enough.
Aug 07, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
I need to repalce the elctrical supply cord and water supply line to my Fisher & Paykel DD603 dishwasher, but I'm unsure as to how to remove the terminal box cover. Could you please help? Thanks.
THIS IS SIMALAR TO THE BOSCH UNIT, IF THERE IS NO BOTTOM COVER TO REMOVE YOU NEED TO TAKE THE SCREWS OUT OR THE TOP INSIDE THAT HOLD IT TO THE COUNTER TOP, PULL THE UNIT OUT SLOWLY, TURN OFF THE WATER SUPPLY SHOULD COME OFF THE HOT SIDE OF YOUR FEED LINE TO THE FAUCET UNDER THE KIT SINK, THE WATER SUPPLY IS ON THE LEFT LOOKING AT IT AND THE ELECTRIC IS ON THE RIGHT IF YOU CAN PULL IT OUT ABOUT 8 INCHES YOU CAN GET TO BOTH CONNECTIONS TO BE ABLE TO DISCONNET PULL OUT ALL THE WAY GET BEHIND IT AND CHANGE WHAT EVER YOU NEED TO
May 29, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Detergent dispenser - Fisher Paykel dishwasher DD603
manufacture does not reccomend using tabs, small amounts of powder, will work jsut fine
Dec 25, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel DD603 Service manual
i need a parts manual for a fisher & paykel dw681es wh
Nov 10, 2008 | Fisher and Paykel 23 in. DD603H SS...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
135 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
