Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Which part(s) to replace?
The top 25% and the bottom 10% of the screen turns to yellow with an arch. Therefore, only the middle of the screen with an oval shape has somewhat the correct colors and it's "framed" with this yellow hue. Also, I notice the image of the yellow regions repeats itself towards the middle of the screen in blue. Unplugged the tv for couple hours, replugged and turned on tv. The screen first look cured but the discoloration appeared again in couple of minutes.
Reading from the existing posts, it seems that the convergence board(s) have failed and three replacement part numbers are called out (BP94-00155A, BP95-00142E, and BP95-00415B) to fix the problem. BP94-00155A and BP95-00142E look similar, so which one should I get? Or do I get the BP95-00415B? Or both?
Where is the fan?
Posted on May 06, 2008
  • Samsung Master
  • 5,568 Answers
If the screen looks OK after extended cooling is provided, you may just have a failed cooling fan.
Turning the blade with the power off will tell you if the bearings have failed or stuck, or just look at it with a flashlight to see if it is turning.
Check this first before you start replacing boards.
Posted on May 05, 2008
American camper tent 2455 setup
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Apr 09, 2013 | Sport & Outdoor - Others
Apr 09, 2013 | MSR Family Tents
Instruction for setup of American Camper tent 8x11
Aug 28, 2012 | MSR Kamp Rite Double Tent Cot
I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT IF ANYBODY CAN HELP ME ON MY SEARCH TO FIND SOME INSTRUCTION
Jul 12, 2010 | MSR Family Tents
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
shaun
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
The 3 colors are off, i have shadows and arches in the screen
It is failure of convergence ICs and these two ICs will be replaced on D board.
If you are comfortable with TV repair and know good soldering skills then can do the job easily.
Convergence ICs are mounted with sliver heat-sink on D Board of TV and part number will start with letter STK...
Get back to me if you need further info.
Jan 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Re Degaussing
Now Degaussing and convergence are two different things, if you say its degaussing then you should have just a color differential in a certain area, meaning the color should not be arched, everything that passes through should pass throu only with the changing of color. Now if its a convergence the the color may lift upward in an arch, likely separated from the other colors, Red, Blue,or Green. So now which do you think you have? Deguassing usually give you a highish green color or yellow
Sep 11, 2007 | Panasonic PT-47WX52 47" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Henry  Thomas
Henry Thomas
