Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
We got a new refrigerator today around noon....the ice maker hasn't filled with water yet (it is now 5 PM)8E761d52....how long does this take?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
Ge refrigeration model 20-25 icemaker not making ice
Fill ice maker with tap water and allow the water to freeze. If when the ice maker cycles and drops ice into ice bin it chooses not to refill with water at end of the cycle. That would point to the dual water control valve. If ice maker does nothing when filled with tap water that will indicate a defective ice maker. The model number you listed does not appear to be correct. Look around the fresh food section door frame and see what you have. This could be the ice maker or the dual water control valve causing this problem. Thanks Sea Breeze
Nov 16, 2012 | GE 20.3 cu. ft. Bottom Freezer...
Ice maker water keeps frezzeing up where the water goes ln to ice maker.control is set on 5
Hello, Thank You for using FixYa. I will be helping you today.You need to replace the fill valve it is leaking and causing the fill tube to freeze. This is common when the valve is going bad
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Hotpoint Refrigerators
Fill tube to ice maker keeps freezing up. Replaced double water valve and worked good for a week. Stopped up again today and found a leak in elbow going up to water in door. Would this let water leak into...
1.Check water pressure is lower than actual. Turn it full flow.2.Check water filter, replace it if over dust particles. 3.Freezer setting may be very low. Increase it. Better to keep in 5 degree always.
4.Inspect the water hose from one end to the other. If there are parts that are bent or pinched, the water will not be able to pass through and chances for get freezes. Thanks.
Jan 24, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Can I trigger the KitchenAid Superba KTRS25Q ice maker to fill?
THERE IS A WAY TO (JUMP) THE ICE MAKER BUT I DONT RECOMEND IT BECAUSE IF YOU JUMP THE WRONG WIRES YOU CAN DAMAGE IT. TAKE THE COVER OFF THE ICE MAKER AND LOOK IN THERE IT MAY SAY HOW. OR WAIT
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | KitchenAid Superba® (KTRP22KRWH) Top...
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice maker is not filling with water.
Check the water valve on back that sends water to ice maker Sometimes the coil is bad and sometimes the ice maker is not telling the valve to open. Visit my link below and enter model number of your refrigerator in model and parts search feature. We offer free help and assistance, Thanks, Sea Breeze seabreezehvac@yahoo.com
click link below
http://servicepartstec.blogspot.com/
Mar 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Very little ice
We just hooked the water up today at 1:00 PM and I have a few cubes but it is not full. How long does it take to fill it up? Is there something I can do to fix the problem?
Oct 23, 2007 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
22 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
