Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side. Both sides other refrigerator has stopped getting cold. Set tempature to 9 and still does not work
  • GE Master
  • 43,501 Answers
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a rel='nofollow' href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a rel='nofollow' href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a rel='nofollow' href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Posted on Aug 25, 2010
GE refrigerator model GSH25KGRB # HG256690 NO WATER OUT DOOR.
I use a hair dryer to defraust the door. This refrigerator is very sensitive to tempature change. When it gets cold out and you have the tempature on high, the water freezes in the door.
I cover the opening of the freezor with a piece of plastic cut to fit. I tape it in place with blue tape. I tape the door switch down so the you can test the water to see when it is running again. I use the hair dryer With the door open I concentrate the heat on the right side center section. It usually takes about thirty minutes. I put a glass in the water compartment and I try the water every few minutes until it flows. Finally, I run the water for two or three minutes after it starts to flow to make sure all of the frozen water is clear. Thom
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
May 28, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Tempature problem
hi thanks for the question what number is the thermostat set at. if at a high number reduce the nubber lower if its set low now and still freezes you need a new thermostat thanks the appliance doc
Sep 27, 2008 | Amana ASD2625KE 26 Cu. Ft. Side-By-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
18 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
