Question about New Bright Remote Control Toyota FJ Cruiser
Need battery charger for 19.2 battery - New Bright Remote Control Toyota FJ Cruiser
  • 748 Answers
Hi
New Bright is in Wixom Michigan. Their web sigh is: http://www.newbright.com/cont.cfm Email them for a battery.
Posted on Aug 26, 2010
Need battery charger for jump start vec021stc
If your model jump starts 12v batteries, it likely will be the same as this generic replacement charger on Amazon. http://amzn.com/B009DF2J52
I replaced mine and the open circuit (no load) voltage of the charger is from 18-19 volts. But it charged perfectly.
Mar 29, 2014 | JUMP START SYSTEM
Tips for charging new batteries in Jazzy Select Traveller
Check the charger output to verify whether or not you have a bad charger using a voltmeter. These smaller batteries are notorious for having a short shelf life and poor quality control from the manufacturer. Load test the batteries after you verify you have a working charger that will bring the batteries up to the proper voltage first.
Feb 24, 2014 | Electric Mobility Pronto M41 Power Chair...
Where do I find a 21.6 volt battery charger for a Kawasaki saw?
http://www.ebay.com/itm/Kawasaki-Battery-Charger-for-19-2V-Batteries-690072-New-/160992931850?pt=US_Power_Tools_Batteries_Chargers&hash=item257bed300a
or
http://www.ebay.com/itm/Kawasaki-691760-Class-2-Battery-Charger-Cradle-Base-7-2-24V-1-5A-/261150260383?pt=US_Power_Tools_Batteries_Chargers&hash=item3ccdc4bc9f
Mar 19, 2013 | Saws
Battery charge light flashing amber
Ok, lets start slowly, do you have both a new battery and a new battery charger? If both attempt to use your old battery with the new charger. Also could be a bad charger or a shorted out battery...
Good Luck
Feb 13, 2013 | HP Compaq nx9600 Notebook
Hi, i have svoa labtop and now my charger adapter got burnt due to electrict short. Now my charger is not working and i cannot use it.
OK. But I don't understand what the problem is.
AC adapter (Charger) is burnt out, by a new one.
Look at the old 'charger'.
Look at the label.
Input: 100 ~ 240VAC/50 ~60HZ.
100 to 240 Volts AC, at 50 to 60 Hertz. (Cycles per Second)
Output:
This is what you need to know.
What is the output voltage of the original charger?
Example;
Output: 19VDC @ 4.63A
19 Volts DC at 4.63 Amps. (Amperes)
Your charger MUST put out 19 Volts. (For the example)
It WILL be DC electricity, so don't worry about that. (Direct Current)
[Your 'charger' is more than that. More than a charger for the laptop battery.
It is also a Converter. It converts the 100 to 240 Volts of Alternating Current, (AC), into a low DC Voltage.
Plus it charges the Battery, WHEN needed ]
Post back in a Comment as to what the exact query is.
Regards,
joecoolvette
Jan 25, 2013 | Computers & Internet
Need a battery charger for the 21.6 volt battery
It will work if it is of the same charger/receiver style. The only issue is that you will only be charging to 19 volts and not 21.6, I would estimate by doing some simple math that you would lose about 6-8% of the batteries capacity but you would be able to use it.
Jun 05, 2012 | kawasaki 21.6 volt Cordless Drill Driver 2...
I have a pd360 Type 2 3.6 Volt Pivot screw driver and I don't know how to charge it? I've misplaced my paper work for the tool. Can you help me?
Usually, the battery is removed from the tool and inserted into the charger base. Hopefully, the charger has not disappeared also. Good luck!
Oct 16, 2010 | Black & Decker Garden
Batteries not charging
sounds like my charger, not making good contact
wiggle the battery around while pushing down and you can probably get it to make contact
sounds like you just need a new charger
Nov 11, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Mar 16, 2009 | Ryobi Drills
New Bright Remote Control Toyota FJ Cruiser Logo
140 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
