Question about Garden
Have an old IR75 air compressor that will not build pressure in the tank-serial # sndc87052.can you give me any ideas on repairing. live in Minneapolis,MN
  • 104 Answers
SOURCE: coleman powermate inflationmate pump
The ring is gone on compressor. You can buy replacement pistons and rings from colemen. Comes with instructions.Good luck
Posted on Oct 26, 2008
  • 1388 Answers
SOURCE: WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Posted on Nov 27, 2008
mrhappyface
  • 205 Answers
SOURCE: air compressor fills, but slows down as the pressure builds
sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
Posted on Mar 23, 2009
  • 59 Answers
SOURCE: Drain valve in Porter Cable air compressor
this valve works backwards, you screw it out to stop airflow. If that doesn't work, replace the valve.
David
Posted on May 25, 2009
  • 1949 Answers
SOURCE: My porter cable air compressor
right where it goes into the tank there is a oneway valve that is stuck or bad and needs replace
Posted on Dec 24, 2010
Air compressor slow to build pressure, and noisy.
All large air compressors are very noisy.
How long it takes to come up to pressure depends on the size of the compressor piston(s), how fast they are running and the size of the air tank attached to it. (and if the tank or hoses have leaks)
A 20 gallon tank could easily take 10 minutes to get all the way up to 120 psi. 120 is very high, and probably the limit for the compressor. Depending on what you're using it for, try dropping the setting to say 80-90psi.
Sep 25, 2012 | Air Tools & Compressors
How to Fix an Air Compressor That Doesn't Build
  • If you are asking is it possible to repair a leaky air compressor tank the answer is no, not without risk of life or death. When the pressure builds great enough, what ever has plugged that hole, will blow out and it will hurt of kill whoever that plug happens to hit.
Regards, Tony
May 22, 2011 | Air Tools & Compressors
Compressor squeaks as pressure begins to build. Not from belt. Does not squeak when no pressure in tank.
Air leaking back from tank check valve or leaking reed valves can make a squeaking or vibrating noise. With pressure in tank remove fitting at the tank check valve and test for leak with soapy water. If leaking, replace with generic valve. If no leak, reinstall fitting and let all the air out of the tank. With empty tank and air filter removed, start compressor and feel strength of suction at intake. When you hear the squeak retest strength of suction at intake and compare. If reed valves are leaking, you will feel less suction as tank pressure increases, and in severe leaking valves, you will actually feel air blowing out of intake. Repair/replace reeds and /or leaking gaskets in head of compressor. Good luck
Mar 08, 2011 | Ingersoll Rand IngersollRand SS3F2GM...
Compressor runs, builds up pressure, but wont come out of hose/???
When the pressure regulator fails, no pressure will be available at hose. Replace the regulator with generic available at Lowes or bypass. To bypass the regulator (this method will give you full tank pressure to hose) remove the safety valve (or gauge if it threads directly into tank) and install a tee fitting. On one side of tee fitting reinstall the safety and the other port is for quick connector. You can also install a regulator here if you would like to save time and the old regulator is difficult to remove. Good luck
Feb 12, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Will not allow me to regulate air. compressor kicks on and builds to max pressure.
All air compressors build pressure in the tank(s) to their maximum allowed by the pressure switch. The regulator only controls the pressure of the air available at the outlet. That's why they have two pressure guages, one for tank pressure and one for outlet pressure. If you cannot control the air pressure at the outlet then you have a defective/broken regulator. Dewalt does not make the regulator as a seperate part for their air compressors, you have to buy the entire manifold which includes a regulator to fix this problem.
Jan 31, 2011 | Dewalt 2 Hp 4 GAL Air Compressor
Craftsman pro mod# 919167770 , oilless air
Check to be sure your drain valve under the tank is turned completely off first
Mar 12, 2010 | Air Tools & Compressors
30 gal compressor - trips the breaker when I turn it on Model 919165130 Serial 2016180483
Try draining the air out of the tank,all of it.Now turn on the compressor,if it will come on,and build up to the cut off point,then the check valve/pressure release valve is bad,replace it.
Aug 29, 2009 | Air Tools & Compressors
Electric Air compressor
check the valves. They could be breathing in and out and not sealling.
Oct 30, 2008 | Air Tools & Compressors
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
