Question about Rockford Fosgate Power T3002 Car Audio Amplifier
I have rockford fosgate t3002 amp with 6 gauge wire. a pioneer 12 premeir sub svc 4 ohm. maybe i should get 4 gauge wire but the dude at the shop said 6 would be fine. now my problem is when the car is off the sub straight up dumps. when the car is on and running it makes a crackling/rattling noise. its not bridged because theres something wrong with the right channel. when i tryed bridging it, it jus pushed the sub to the peak of its excursion nd stayed there. sounded like poop. but the left side works fine. somebody help. thanks.
Can I wire two p3 12 Rockford fosgate subs to a kicker 250.1 amp
It has two speaker terminals which allows you to wire muliple subs to the amp easier than trying to cram the wires all into one set of terminals. The two sets of terminals are wire in parallel internally on the amp, so it matters no which + or - you use on it. However, you need to remember they are already wired in parallel internally, so if you were to wire up two 2 ohm subs, the amp would see a 1 ohm load (which it's not stable at), not a 2 ohm.
May 04, 2015 | Rockford Fosgate Car Audio & Video
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
When my bass hits, my car lights flicker.
Is the problem much more noticeable when the car is at idle? Double check that Alternator output. 70 amps is not high output, and if the problem is especially noticeable at idle, it's probably due to the alternator putting out lower voltage( a common thing with alternators). Also, with that much draw from your sub amp, the wire from battery to alternator should be beefed up, as well as the ground wire from battery. You can make up your own cables by purchasing the wire to length and wire lugs at a local Welding shop, 4 gauge from alternator to battery is good. High output aftermarket Alternators shoot into the 200 amp range.
Aug 20, 2009 | Rockford Fosgate P112-200 Car Subwoofer
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Amp or something cutting out.
Power caps store power from the battery and they feed constant power to the amp so you dont get no drainage! this could be one reason..
have you bridged both subs and wat gauge wire are you using.
these amps can only handle one bridged sub at 4ohms and this amp is recommended that u use 8gauge or higher. if your running to subs i normally reccomend using 4 gauge power wire as you get more rms power feed to the amp
you can get a power cap or anyother accersory cheap online at my suppliers.. caraudiosecurity << click to enter >> hope this helps and please rate me :)
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Fosgate Punch 401s starts then smokes
Can somebody email me the schematic for the Rockford Fosgate 401S?
Feb 04, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford Fosgate Power T3002 Car Audio Amplifier Logo
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
