Question about Thomson Televison & Video
I have a (Thomson) RCA Model # P46738AT / Ser # 443686992 / Chassis # PTK169PGA Big Screen TV. The part where the cablevision cable plugs in to the back of the TV (Ant A, Ant B, Converter) was jerked out and broke away from the base. Only the Antannae A is broke, but probably have to replace the piece with A,B & Converter slot. Can you help find the part?
  • Thomson Master
  • 5,138 Answers
Mats Electronics has them IF connector,and you can call some local TV shops ask if they are junking out any older models and if they have any .1-800-628-1118
Posted on Aug 25, 2010
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I just acquired an RCA P46738AT television set made in 1994- 1995. The TV makes a quiet charging noise when it is plugged in but no light on the power button and no power. Not sure what to do about this...
This is a common problem and chassis (CTC169) and it sounds like the HV block is bad. Part# 205064. Caution is required when replacing since High Voltage is present.
Sep 27, 2009 | RCA Televison & Video
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
I have problems to finding a diode to my tv
DL301 is a 24V 1.3 watt zener diode the RCA part number is 259971 heres where you can get one.
http://www.partstore.com/Part/Thomson/RCA/259971/New.aspx
Feb 03, 2009 | RCA R52WH73 Projection Television
RCA P46738AT 46" rear projection No Power
hi i have the same situation with my rca same model number, did you ever find a fix for this??my email is gmd400@gmail.com please let me know
Aug 18, 2008 | Televison & Video
19, signal 19, 19, what is it trying to tell me?????
The only error code 19 for the ITC222 chassis listed from RCA/Thomson for 19 is invalid chassis detected. Which doesnt make sense unless you have replaced a PCB with a wrong part number.
Jul 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Service Manual
You can get the service manual emailed to you at the following link. The manual is listed under Thomson the ITC222 chassis is a thomson which is RCA It cost 12.99 but they provide free on line tech support to help you with your diagnosis and repair and they also sell parts with free installation instructions.
http://servicemanuals.vstore.ca/
Apr 13, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
