Question about Admiral AAV7000A
One of the pulleys underneath has waht looks like melted black plastic on it, it started making awful noise then we smelled rubber burning, then it wouldnt go at all. tipped it over and sa belt intact, but pulley lookedawful, also, all three pulleys turn with no problem by hand, hep!
  • Admiral Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Yes, that is not that hard to fix and you can easily buy the parts yourself online...<br /><br />Here is a tip that will help you with the online buying...<br /><br />How to Buy Appliance Parts Online<br /><a rel='nofollow' href="http://www.fixya.com/support/r3907570-buy_appliance_parts_online" target="_blank">http://www.fixya.com/support/r3907570-buy_appliance_parts_online</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Posted on Aug 25, 2010
Burning rubber smell when slowing down in an 89 Ford Bronco XLT?
Check under the car and look for a plastic bag that may have melted on the exhaust.
Feb 20, 2014 | Ford Bronco Cars & Trucks
Timing belt? smell of burning rubber?plastic?
Did you mean serpentine belt? If so remove the and ensure all the pulleys are spinning free. A seize pulley such as A\C compressor or tensioner pulley can created more drag or friction making the belt hot and burn thus giving you the burning rubber smell.
Oct 23, 2012 | 1993 Pontiac Grand Am
Smells like burning rubber
sounds like a bad bearing take the belt off and see what pulley is hard to turn look for the one with dark marks on it from the belt
May 12, 2012 | Craftsman Garden
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Grindin noise on My 97 Dodge Caravan when heat is turned on .
yes,could be something in there rubbing against fan cage.
Nov 15, 2008 | 1997 Dodge Caravan
Smoke coming from back of washing machine and a burning rubber smell
You may have overloaded the washer and the belt drive system could not handle that excess mass.. The smoke and burning smell is a belt melting while trying to rotate the drum.. I would unload it .. gain access to the drive mechanism ( probably via an access panel in the back but may not be.. - brand and model specific).. and then check for damage to the drive belt.. You may look at the pulley system and look for burnt black from melted belt on it.. You could also have a clog in your pump that the belt drives but can't ( because of that clog) and therefore the belt rubs over the pump pulley and melts.. Could be any one of those things.. Hope that helps..
Aug 24, 2008 | Washing Machines
Plastic pulley melting
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
Mar 15, 2008 | Maytag Atlantis MAV9750A Top Load Washer
MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Dec 16, 2007 | Maytag Performa PAV2200
Admiral AAV7000A Logo
62 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
