Testing boat How do I connect wate to a 250 chevy motor to rest it out of water?
  • 5,568 Answers
Dunno why you ended up here but you will need hoses and at least one barrel of water to recirculate, two would be better, a children's swimming pool even moreso.
That supply of water will get hot very quickly otherwise and cost you a headgasket at least; seized bearings could follow.
Monitor the temperature of the water (a hand will do nicely!) and waste some additional cold water if needed.
Posted on May 05, 2008
Boat motor will not turn over with plugs in but will spin freely with plugs out why?
battery reading 12.6 volts at rest? starter motor brushes ok?
Jul 27, 2017 | Boating
What size motor for a 1970 15ft. seaswirl boat
outboard??? you could go all the way to 40 hp but id not recommend that much , but maybe a 20 hp would be just right !! its all about the condition/design of the transom and how you want the boat to sit in the water (weight) at rest ive seen motors as low as 10 hp on boats this size
Feb 29, 2016 | Boating
Water in the oil of my 4 cycle Suzuki boat motor, what could that be
without a model number its impossible to tell weather you have a oil/sealed water/water heat exchanger or water is directly circ thru block , if its the latter 4 sure you have a bad head gasket ( Happens on aluminum block) if its the first one id 1st ck the heat exchanger O ring seals
Nov 13, 2015 | Light Outboard Motor Boat Bass Fishing...
Torque specs chart for a 165 hs pwr in line 6 mercruiser
That should be a Chevy 250 Cubic inch block. I would look in a manual from the late 70's
Aug 04, 2014 | San Juan Engineering Freshwater Engine...
Just bought a used boat, 1966 sportscraft with an evinrude 2 stroke motor, don't know how to test the motor without going into the water. don't know much about boats
Hi. If you just want to run the motor then you can do it in you driveway. Go to a sports store with boating equipment and ask for "Muffs" to run your boat motor out of water. You can see a pictures of outboard motor muffs on google images:
Take the muffs and place them over the water intakes located above the propeller (look like vents on each side). Hook a garden hose up the muffs and start water flow. Make sure nothing is near the propeller. Make sure to pump the bulb in the fuel line to the motor until it stiffens. Crank the motor. When the motor starts, you should see water start to flow out of the back of the motor near the cover and out of the center of the propeller with the exhaust. You must keep water flow to the motor using the muffs while it is running or it will burn up.
Apr 27, 2010 | Boating
Electric motor for boat vs battery
hi older motors 7/10 years ago did draw more current but there is more to this the test you gave the battery isn't realy accurate but to lose so much power in so little time does not make sense the prop was ok out of water but not in it if the prop is rubber bushed they can slip try the whole set up out of water don't run it without a hosepipe squirting on the motor or it will overheat check all connections for corrosion and tightness on the side someware it will state the voltage and amperage run it with an ampmeter in series if it is drawing too much you will see it if you can give it back !! i know this has not been much help ,if i had it in my w/shop i would know in secondswhat was up but i havn't sorry merlin v12
Aug 19, 2009 | Boating
350 CID Kodiak 5.8 L chevy marine engine has water in oil
stuck thermostat bad water pump impellar about only 2 causes first check thermo should be located in the housin where all the hoses go into the motor u can check it with a pot of boiling water and a temp gaige put in water nd see what temp it opens at shop cost estimate $85.00 with part impellar estimate depending on location $200.00
May 28, 2009 | Boating
Televison & Video Logo
Top Televison & Video Experts
