Question about Compaq tc1100 Tablet PC
Battery problems Tc 1100
My tc1100 is only working on AC power.once i unplug the power cord it goes to standby and asks me to chnage battery or plug it on power if I dont want to lose my work. I pressed the button at the back of the battery only one is lit up.. What can I do?
  • tjgannon Feb 27, 2009
    I have tried to change out batteries and that didn't work. I think the internal chagring unit isn't working. Anoine know how to fix this?
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
Posted on May 09, 2008
TC 1100 UNSUPPORTTED WIRELESS DEVICE
Have you got the drivers installed for the OS you are using?
Jun 23, 2014 | HEWLETT-PACKARD Hewlett Packard 348349-001...
HP tc1100 power issue
Go to ebay and search for "tc1000 charger". You'll be able to find one for 10 at the most with free shipping most the time.
Nov 28, 2013 | HEWLETT-PACKARD Hewlett Packard 348349-001...
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
My hp tc 1100 will boot up it goes into scandisk hen before it starts it reboots again and it keeps on going
try pressing F8 then safe mode with command prompt after that when the windows is open type chkdsk on the command prompt. then after its finished scanning press quit, if it has an error type chkdsk/f to fix the problem.
Jan 04, 2010 | Compaq tc1100 Tablet PC
Pen pointer problem
you can try calibrating the pen that would probably help
Jun 02, 2009 | Compaq tc1100 Tablet PC
Does not turn on under battery power
Battery may be faulty, perhaps you can swap with another user to rule this out. Do the battery charge level lights on the back of the battery show a full charge? (Press the rounded square button on the back of the battery itself and note whether the 3 green leds light up or not) Has the battery been calibrated? (You will need the "toaster" style or the DT533A charger to do this). I assume that your battery is secure and properly seated, but try taping it down from the back side just to be sure it is snug. Don't use duct tape, just regular scotch style tape or blue masking tape. Also try laying on your back to hold the unit upside down and power it up. Check the small metal fins that mesh with the battery. They are right above the right side of the windows cert of auth sticker when turned as you would to read it. They are NOT all the same length, do not push or pull them, but if one is bent you may try to straighten it VERY carefully with very small tools.
What happens if you unplug while up and running?
How does the power jack feel when you insert or remove it? any looseness may indicate your trouble. A good tech can repair your trouble. Are you sure that you are not under warranty? HP still sells extended warranty for these machines. My original warranty expired in Sept and I bought extended warranty for another year. I'm in central MO if you are close by at all I would meet up and swap a batt for a minute for you. Also, you may get a lil more usability with a car cord if the problem cannot be resolved at all.
Best of luck! I love my tc1100 and the older brother tc1000 as well. I have several of each.
Mar 27, 2008 | Compaq tc1100 Tablet PC
Key board problem
check you keyboard in Regional settings and see that it is set to a 101 type (US or Aust) otherwise key location can change,also are you talking about Shift Keys or the Up/Down, Left/Right scroll arrows, let me know, otherwise something has gone arye on the keyboard itself.
Dec 12, 2007 | Compaq tc1100 Tablet PC
The AC adapter light does not come on when plugged in
This happened to me recently. I did as the engineer said and it worked.
Compaq tc1100 Tablet PC Logo
331 people viewed this question
Top Compaq Tablets & eReaders Experts
Jerry Umali
Ann
Level 1 Expert
ray gallant
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
