Question about GE Dishwashers
I have a 4 year old GE Dishwasher model GHDA470M00BB. Now it will not drain. I checked the drain line and it is clear. I removed the line from the machine side and remainder of the water i was not able to remove from the machine ran out. Where else should I look for the problem
  • GE Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that I wrote that will help you with your dishwasher not draining problem...<br /><br />Dishwasher<span style="mso-spacerun: yes"> </span>Problems - Water will not drain out<br /><a rel='nofollow' href="http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain" target="_blank">http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span>
Posted on Aug 25, 2010
The GE Profile Dishwasher does not drain completely. The bottom drain shows no obvious clog and the screens are clear. The overflow drain in the back of the washers the only reason the dishwasher does not...
Uncouple the drain hose connection under the sink and use a wet/dry vacuum to **** out the drain hose and the stub on the sink drain plumbing to clear any possible clogs. There may be a blocked check valve near the pump that might have to be cleaned or replaced. Check the hose itself for any kinks or collapsed section. There might be a damaged drain impeller on the pump. Hope this helps!
Mar 11, 2010 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher won't drain?
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 15, 2009 | General Electric Adora GHDA670N Built-in...
GE Dishwasher model PDW8200J03BB stopped draining. Removed the drain pump, checked with Voltmeter and there is resistance on ohms X10 of about 3. The flap is in place so water isn't shooting back into the...
clear the line from the air gap to the drain,, if the rest is clear the only thing it can be is the propellers on the pump, i which case you will need to change the pump
Jun 06, 2009 | GE 25 in. Profile PDW8200J Built-in...
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
Other wise you need hands on service!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwasher not draining - Kenmore dishwasher model 15754
depending on the age of this unit it may have food blocking what is called the "check valve".
on most models it is mounted right on the outlet of the pump housing. one model uses a 4 inch plastic tube style device and is about 1/2 inch on the pump and 1" on the hose. inside of it is where the food items can block the check valve. remove the hose and unscrew the check valve from the pump and see if something is blocking it.
on newer units the check valve is built into the drain hose, if you hose has a 90 degree elbow molded into it where the hose hooks up to the drain pump. once again take the hose off and look inside the hose or try to blow through the hose and see if the hose is clear.
good luck tom
Sep 16, 2007 | Kenmore 24 in. 16222 Built-in Dishwasher
Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | GE 24 in. GSD4060JSS Built-in Dishwasher
I hav an Americana / GE dishwasher, only one and a half years old. the dishwasher is not draining. When I turn the selection knob on the front to wash, is begins filling with water again. But, the cycle is not actually working. I removed the drain hose from the disposal unit and allowed the really really nasty collection of water to drain out. I have a feeling that the hose connection to the washer is clogged. Is this possible. If so, should I remove the hose from the connection at the dishwasher and clean the hose or could it be something else.
Thank you,
Aug 31, 2007 | GE 24 in. GSD4320Z Built-in Dishwasher
Dishwashers Logo
76 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
