Question about KitchenAid P Series Trash Compactor - 15" - Black on Stainless Refrigerators
My Whirlpool trash compactor starts knocking at the end of a crush cycle. I have to press the 'off' button to make it stop. I've been told I need to replace the 3-button switch. My model is GC900QPKBQ, I think.
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: GE Profile trash compactor
Sure is... The motor drives a ram up and down to compact your trash... Like most drive systems.. it needs to find a refrence position near the top of the stroke.. that position is normally sensed by a switch.. so it is possible your motor is bad or.. it is also possible your top sense switch is bad too.. For $400.. the GE tech should come out and stomp on your trash until it is compressed.... In either case.. if you are handy.. you may be able to open the compactor up ( with power unplugged) and check the position of the ram.. if it is near the top.. you may be ableto reposition it down a little then try cycling it.. It may buzz if the motor is bad ( windings shot) or it may work OK.. if it does and the problem comes back after you cycle it.. there is a good chance the top sense switch is bad or the windings in th emotor bad too.. Hope that helps...
Posted on Aug 17, 2008
appldoctom
  • 311 Answers
SOURCE: ram will not reverse at end of cycle
ive been a repairman for 17 years but havent had to fix a lot of these because ther not out there,but have done some.it drives on a worm gear and i suspect that theres some wear there and its jumping the gear and thats where your getting the poping noise.their not the funest but you,ll have to take apart and opperate and watch/inspect.hope that helps God bless
Posted on Jan 04, 2009
SOURCE: My KitchenAid trash compactor model KUCP021RBL1: cycle does't end
Most likely the motorwindings have been overheated after staying to long time in down position and trying to get up.
If there is a Emerson motor in your compactor than you will not find anything wrong most likely it is the winding of the motor, we have had this two times, changed the motor and the problem is solved.
Kind regards,
Paul
Netherlands
Posted on Mar 04, 2009
SOURCE: Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Posted on Dec 25, 2009
How can i fix a trash compactor that appears to have gone over limit switch
By over limit, do you mean it makes a knocking sound when the ram comes to the top and wont shut off until you press the off button? If that is the case, chances are the "Start" button (switch) is stuck in the closed passion. This is a mechanical issue with the switch that you might be able to clean the contacts and be done with it. The worse case is you'll have to replace the switch panel because you cant change the switches individually. If you do that will set you back about $100.00. I hope this helps, good luck.
May 26, 2014 | Kitchen Appliances - Others
Trash Compactor Thumps
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
May 04, 2013 | Kitchen Appliances - Others
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
Kitchenaid compactor KUCS03FTSS makes banging sound at end of cycle
I bought a Kitchen Aid trash compactor the end of Sept/2008. By July/2010 I have spent $528 on having it fixed! It only cost $623 new so I called Whirlpool customer satisfaction line where after waiting 15 minutes was told that "With all due respsect mam, Whirlpool owes you nothing" Then " as a courtesy" they offered me 50% off an $80 part that I still need to pay $60 in labor to install! So,that would be an additional $100 on an appliance that has been trouble from the get go...I have had numerous compactors before this brand and have never had any trouble...Do NOT buy anything made by Whirlpool as they have apparently, a NO customer satisfaction policy.
May 17, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
When cycles completes will not shut off
the momentary switch is bad.
In easy terms; the white push button down low that the foot petal triggers is bad. You can try pushing it in an letting it snap back.
This worked for about a week, but in the end I had to buy the part and replace it. $63 online,
Cheaper than a $75 service call
Feb 20, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor continues to run when cycle is complete
the little white swiitch that the foot petal pushes is bad.
it may help if you push it in and let it snap back.
That was a temporay fix for me, but I ended up having to replace the part.
$63 online
took about 30 minutes to repair
Jan 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Ram will not reverse at end of cycle
Jan 03, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Kind regards,
Paul
Netherlands
Dec 30, 2008 | KitchenAid P Series Trash Compactor -...
Whirlpool Compactor: starts making banging noises....
it sounds like there is something in the motor or a gear is getting ready to go out i suggest calling ge if it under waranty
Nov 15, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
KitchenAid  P Series  Trash Compactor - 15" - Black on Stainless Refrigerators Logo
219 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
