Question about Brother HL-2040 Laser Printer
All lights blinking
All my lights are blinking after a paper jam
  • 3 Answers
Try:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Jun 10, 2008
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
Red lights blanking
1st uninstall printer software in your system and reboot your system them after re install software.
Nov 20, 2013 | Epson STYLUS R230 InkJet Photo Printer
3 FLASHES POWER LIGHT COMMUNICATION PROBLEM
Power light blinks slowly
The printer is out of paper in the middle of a print job.
Load more paper. See "Loading paper" on page 20.
Power light blinks rapidly
There is a paper jam.
Clear the paper jam.
Aug 13, 2012 | Lexmark Z1300 InkJet Photo Printer
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Check paper blink I can;t fild the paper jam but
Turn OFF your printer. Remove such blockage then turn the printer back ON.
Oct 09, 2010 | HP PSC 1350 All-In-One Thermal Printer
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
Paper jam blinking
Try and push the blue button after clearing the jam.
Dec 08, 2007 | HP LaserJet 4L Printer
Brother HL-2040 Laser Printer Logo
427 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
