Question about Craftsman Garden
My Craftsman 42" 18.5hp lawn tractor will start fine but when I disengage the brake or engage the blades it cuts off. It was recently left out in the rain while I was working, did something short out? It was working fine before this happened.
    Problem Solver:
  • 5 Answers
There is a safety switch under the seat. to stay running after the brake is released or deck engaged you have to be sitting on the seat or it will die. if this switch is bad it will die as soon as you release the brake.
Posted on Aug 26, 2010
Craftsman lt2000
Your blades engage with a cable and the cable somewhere is bunched up. You will probably need a new cable.
Aug 05, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
LT2000 had been working fine, but trying to start
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
188 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
